911SC 1982 IMS Bearing Cover leak
I'm having a disastrous time of trying to seal what started as a little drip on my sons 1982 coming from the IMS or Intergear coverI. I took it off cleaned it fitted a new gasket and it became worse, yesterday I removed the cover, sanded it on a flat surface and refitted it using a new gasket and gasket sealer, worse still. Last evening I tried again, I noticed that when you fit the cover it moves around slightly on the three studs, also that the case halves didn't match perfectly. I had a spare cover so tried again, using only the gasket this time, now its like the Exonn Vadez!
Question is, can I use RTV instead of a gasket, if so what brand and any good advice on how to do it? Thanks
Anouska's Daddy 1995-2005 and Forevermore |
Hmm, that's weird. Perhaps its an issue with the case parting surfaces. But yeah, it's not elegant and it wouldn't be my first choice but I would put the stock gasket on and use Permatex ultra Black.
Tighten the 3 nuts in stages, going from one nut to another, and don't put hardly any torque on them. Hand tight is good enough. The more you torque it the more it will leak. |
Thank you for the reply, I am putting torque on it, could that be the problem?
That cover has 3 studs protruding from the case correct? I would pull the studs and carefully clean and level out the surface reinstall the studs spread on permatex and gently torque the cover on. Don't use silicone ever.
If you are putting lots of torque on there, and not doing it evenly, you'll be warping that plate or creating gaps. Go easy. |
Thank you for the advice, going to have dinner and attack it again, have bought Permatex black gasket silicone, will that work?
On my old '80 SC I had a leak at the same place. A new seal didn't fix it. I brought it to a shop and they used some kind of a sealant with a gasket (might have been RTV but I know it wasn't silicone), it's been so long ago I can't remember exactly what they used.
Whatever it was it worked because it never leaked again.
Kurt |
76 911S Targa
Apply sealant to gasket surface and press the parts together. Let the assembly dry overnight then tighten the fasteners until you see the sealant begin to bulge out. Don't over tighten. You just need it to seal.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
