Windshield Washer Power Source
I'm trying to return my windshield washer system to my 74 Targa. I thought I had all the parts, but I cannot find the power source. I've seen pictures of a later model setup and it looks like the power comes from the fender well somewhere and through the trunk wall to the pump.
As always, any help will be appreciated. JT |
1 Black and 1 brown wire coming from the front headlight harness running across the front of the car. They just pop out of the harness where the washer is mounted.
Brown is ground. Black is power with a single spade connector near the front fuse box connecting it to the main dash panel harness. Power to it is switched via the wiper stalk contacts. |
It comes through the driver side front fender wall with some other wires in front of the fuse panel. Sorry no pic since I have a subwoofer and other stuff in the way which is not easy to remove.
Some one else can post a pic for the harness location. |
Thanks guys, that helps.
| All times are GMT -8. The time now is 12:23 PM. |
