Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 911 Technical Forum
1982 SC Battery Drain
I tested my battery on a load-bank and it is fine.
However, if I leave it connected for approximately two (2) weeks, the battery is too drained to start the car.
When I disconnect the ground strap and leave it disconnected for two (2) or three (3) minutes, it sparks when I reconnect it and I can hear a slight tick from somewhere towards what seems to be the passenger side of the car (I have removed the glove box, boot, and engine lid lights and checked that no other lights are lit).
Here is the deal, it appears to be some sort of load. That is, when I touch the ground strap to the negative post it initially sparks (and makes a faint sound like a closing relay or contactor) and then stops sparking. When I use my Fluke meter I show a four (4) or so amp draw that quickly tapers off to around 100ma. When I disconnect the ground strap and connect a test light to the negative post and remove the fuses and check the fuse panel, I have a couple of brightly lit terminals and the rest are faint but slowly fade to nothing.
WTF could this be? I disconnected the antenna, stereo, etc. and I still hear the faint sound of a relay but can't seem to locate the origin. It seems to be centered around the Smuggler's Box or fuel pump area. I don't see any contacts or coils in these locations (at least not on my one-line diagram) and shouldn't all of these loads be switched via the start-switch? I don't see any potential capacitive or reactive loads that are not switched. If I leave the battery disconnected, it holds a full charge. Additionally, I disconnected the clock and it is not the source of the drain.
My 79' Targa can be left for a couple of months and it holds a charge (although I typically start it every two (2) weeks at a minimum unless out-of-town).
Any suggestions would be appreciated. Is this intrinsic to this year or is it something wrong with the vehicle?
It's a low mileage (62,000) coupe originally sold from Brumos.
Old 09-11-2017, 09:39 AM
Mine will generally last 2 weeks or 3 weeks but a month is a stretch. I usually keep it connected to a tender.
Do you have the factory or other alarm system?
Old 09-11-2017, 10:52 AM
SC-targa's Avatar
A failed diode in the alternator?
82 911SC targa (28 tube brass cooler, 22 & 21 mm Carrera A-R bars, 7 & 9 inch Fuchs)
92 Miata
87 Suzuki GSXR-1100
1939 Ford Convertible Coupe
Old 09-11-2017, 01:17 PM
next step troubleshooting is to pull and replace one fuse at a time to determine which, when removed doesn't cause a spark when tapping the ground to the battery -- that will help you identify the open circuit.
Don't believe this applies to your '82, but I traced a battery drain on my '86 to a faulty driver's side door light switch -- the power windows used this switch to deactivate the window circuit when the door was open (designed to let you roll up the windows after turning off car, but before opening door) -- since the switch wasn't telling the windows the door was open, the circuit remained active/energized and would drain my battery after a week.
Old 09-11-2017, 02:40 PM
Load test doesn't reveal a weak cell, new battery time
M
82 SC Twin Plug 3.2 SS ,46 PMO
Old 09-11-2017, 04:11 PM
Heck I'm only 5 not 65!
targa80's Avatar
I would suggest that you connect your multimeter on the amp gauge setting in series with your + battery terminal and your battery cable. Check the current draw and then use the schematics for your model year and start removing the power connector wires on the battery cable. Does the current drop to zero? If it does then ignore the battery cable and connect the amp meter to the power connector wires and remove one fuse at a time and check the amp meter each time for a change. I would do this methodically because there are some items that require switched power i.e. new radio memory settings, factory alarm system, interior lights. This should help you isolate the offending circuit.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 09-11-2017, 04:28 PM
A stock car has a very small current load while parked if all consumers are off. Only the electrical clock demands a very small current. A stock size battery fully charged, in good condition, should last several months and start the car. If not... a consumer should be found and corrected. I would start by looking for interior lights, non-stock electronics and such.
Old 09-11-2017, 05:53 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
I had this exact problem. See what I did here:
120 mA draw
Pretty much what Pat described, but with pictures. Short answer- mine was the lambda system relay under the passenger seat, which cycled itself (buzzed and clicked) though the car was turned off. I replaced the relay and the problem was solved.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs
Alfa 156 2.5 V6 Sportwagon • 2002 E270 T CDI
Old 09-12-2017, 03:17 AM
T77911S's Avatar
you did not say what year it is.
basically what targa said is a good start
you have also done good by removing bulbs.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 09-12-2017, 04:24 AM
It's an 82'
Old 09-12-2017, 08:06 AM
It's been suggested to measure the current draw. But unless I missed it, has that been done?
A vehicle with a draw less than 60ma should easily crank and start after 1-2 weeks.
Dave
Old 09-12-2017, 08:11 AM
aoncurly's Avatar
I had a similar issue (2 weeks then drained) and found that it was the frunk light. I cover my car and leave the frunk unlatched but down. The frunk light would stay on. I disconnected the frunk light and that solved my problem. I suggest checking the light even if you latch your frunk as it may need adjustment and be always-on. In addition, I bought a Battery Tender and now I never worry about my battery charge.
1981 911SC, Guards Red/Black Leather
2014 Audi A6 Prestige, Phantom Black Pearl/Black Leather, Black Optics
2017 Tesla Model X
Gone but not forgotten: 1969 Datsun 2000, 1973 914 1.7, 1976 912E
Old 09-12-2017, 08:35 AM
If you read the OPs first post, he's already removed all the bulbs!
"When I disconnect the ground strap and leave it disconnected for two (2) or three (3) minutes, it sparks when I reconnect it and I can hear a slight tick from somewhere towards what seems to be the passenger side of the car (I have removed the glove box, boot, and engine lid lights and checked that no other lights are lit)."
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 09-12-2017, 10:03 AM
Okay,
followed Targa's advice and I have an initial draw of around 0.440 amps quickly dropping a slowly oscillating 0.008 to 0.018 in about 4 second intervals.
When I disconnect the clock, the oscillating draw stops and I show a steady 0.007 amps. I disconnected all fuses (in tern) as well as the relays (including the ones in the engine compartment) and show no change from a steady 0.007 amps.
I would assume that the variable draw, when the clock is connected, would be due to the clock's internal capacitors.
With the clock connected, I show an initial draw of 0.648 amps (once again quickly dropping to the 0.008 to 0.016 variable.
Still sparks initially with the fuses disconnected.
Anyway, a variable 0.008 - 0.016 amp draw shouldn't discharge the battery in a two week period. The ground strap has was disconnected for over a month and when I hook it up, the starter spins her right up without any hesitation.
It doesn't act like a weak or shorted cell and the battery shows adequate voltage. That draw seems a bit low to drain the battery in less than two weeks.
Old 09-13-2017, 09:22 PM
T77911S's Avatar
you are interested in the long term draw.
the initial could just be a circuit charging up like a capacitor. this is common especially with newer cars, that's why I asked the year.
radios can do the same thing. computers can do it.
Old 09-14-2017, 03:00 AM
The only capacitive load that I can locate (unswitched) would be the clock.
Old 09-14-2017, 08:54 AM
theiceman's Avatar
its that initial .6 amps and .4 amps that would be conscerning to me
your other dras are fine.
have you tried disconnecting the battery between starts ( green knob) , ? if it doesn't start after that guess what , battery is toast . I don't believe in load tests
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Nissan Murano (Audi Support Vehicle)
Old 09-14-2017, 09:59 AM
Here is the deal, if I disconnect the battery for a month or more, when I reconnect it spins the engine over as per a full charge. However, if I leave it connected, it won't start the car after a week and and a half or two weeks.
Actually, I had it disconnected for almost two months and when I reconnected it started just fine. Shows 12.8 volts after a month but only 11 if connected for a week or so.
That initial draw is not reflective of the minor continual draw (and once connected, it drops after a second or so to the 0.008/0.018 amps). I left my Fluke 87RMS on it for several hours (recording) and checked min/max and they were 0.008/0.018 respectively.
Old 09-14-2017, 10:50 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
How did you disconnect the clock? The entire circuit, or just the clock? Because there are other interesting things on that circuit.
If the battery is good (and it sounds like it is) and you're only drawing 8-18mA, your battery ought not be going dead. Joy of joys, it sounds like you have an intermittent fault. Here today, gone tomorrow. But coming back.
You haven't yet located the relay you mentioned hearing in your first post. I'd suggest you take a relay out of your bag of spares (you do have a bag of spare relays, right?) and replace the OXS relay under the passenger seat and see if your problem goes away.
Dru
Old 09-15-2017, 11:00 AM
I did just disconnect the clock and there was a pronounced difference in the current draw. The slight relay/connector sound has been hard to pinpoint. I will check under the passenger seat, per your suggestion.
There is nothing worse than intermittent and/or non-repeatable faults.
Old 09-15-2017, 12:12 PM
