Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 911 Technical Forum
How to lubricate gas pedal and linkages?
1988 3.2 Is there anything you can lubricate on the gas pedal and the linkages? The engine is in the car so I would guess the throttle linkage stuff is nearly impossible to lube? If there are places what to use for lube as well.
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2017 VW Golf TSI
Old 09-13-2017, 12:31 PM
subd
81 sc with 3.6 conversion
16 4Runner trd pro
A lot of mountain bikes
Old 09-13-2017, 12:49 PM
gtc gtc is offline
abides.
gtc's Avatar
Gas pedal is plastic and has no moving parts, so no need to lubricate.
1. Pivot shaft behind gas pedal (under floorboard, plastic bushings)
2. Pivot shaft on transmission (plastic bushings, easy to lube/replace)
3. Shaft on throttle console on engine (under intake manifold near breather cover, metal bushings, hard to reach/replace)
Graham
1984 Carrera Targa
Old 09-13-2017, 01:38 PM
doesn't the throttle cable run along the clutch cable? at least in the sc's I think they do (I may be wrong)
it can be common for those two cables to get gunked together and cause some issues, maybe adding lube to the clutch cable can help...
thinking out lout '
16 4Runner trd pro
Old 09-13-2017, 01:56 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Send a message via Yahoo to KTL
Here's a thread that touched on the sleeves/bushings that carry the throttle rod in the center tunnel
Throttle Rod Bushing - Replacement
Kevin L
Present: '86 Carrera, '79 911SC widebody conversion rolling racecar shell
Past: '87 Carrera
Old 09-13-2017, 02:05 PM
steely's Avatar
Any and all of the ball & socket end of the linkages can be cleaned of grit and lubed. (grease)
There is one on the plastic gas pedal too.
Consider replacing the plastic/nylon(?) bushings of the accelerator pedal cluster (901 423 253 00 M105) and transmission bellcrank bushings with bronze ( 914-423-211-00-M105). This would be part of a pedal cluster project. A picture of the pedal cluster throttle crank with bad crumbly bushings and the tranny bell crank with new bronze bushings is below.
There is another bell crank on the top of the engine deck that can be cleaned, lubed, and have it's bushings replaced (check/inspect for 2 springs as well). It is where gtc describes his item 3) above, but will require intake removal. I don't have those 2 bushing PNs on hand.
I did the above over a couple years as part of other mini projects while I was in the respective areas. I have not done the tunnel bushings yet.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 09-13-2017, 03:00 PM
