Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Adjustable spring plates
It has been suggested (by a mechanic) that I might want to consider adjustable spring plates for my 83' SC.
I would welcome any input about the performance of this upgrade (is it worth it, not worth it, etc...)
And any recommendations of adjustable spring plates (brand or manufacturer) that are great and well worth it, or ones that are horrible and I should stay away from.
Old 09-13-2017, 06:24 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
I would rather be driving
jpnovak's Avatar
You should already have factory installed adjustable spring plates.
The only advantage is when you setup and corner balance the suspension.
72 911T project car. "Minne" - A tangy version of tangerine
classicautowerks.com - EFI conversion parts
Old 09-13-2017, 06:39 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Elombard's Avatar
yeah the aftermarket plates speed up the process of rear suspension changes. Are you adjusting your rear suspension ride height, camber and toe a lot?
Erik L.
erik.lombard@gmail.com
84 lime green back date (LWB 911R with RS rear flares) hot rod - absolute riot to drive!
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 09-14-2017, 05:36 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Counterclockwise?
Why is your mechanic suggesting this?
Rod
1986 Carrera
2001 996TT
Old 09-14-2017, 07:58 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
that is one of the first things that I upgrade. Always at all times!
08 Aston Martin Vantage V-8 (6 spd manual) (DD)
12 Cayenne S Hybrid (hers)
78 930 (heavily modified)
08 GT3 RS (white/black) (modified of course)
67 911S
Old 09-14-2017, 06:19 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
83 911 Production Cab #10
JJ 911SC's Avatar
Maybe...
Who Will Live... Will See
83 911 Production Cab #10, Slightly Modified: Slanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger
Old 09-14-2017, 06:38 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Bill Verburg's Avatar
For extreme wheel fitments where wheel back space is critical the location and configurations of the trailing arm adjusters can be important.
stock and the various aftermarket versions will differ in this respect.
Bill Verburg
Old 09-15-2017, 06:14 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
I did a complete suspension refresh in my garage last winter, very happy with the results. I went with adjustable spring places b/c of the savings that I'd realize for the alignment done by my local wrench. Doubtful I'll adjust the height again, but now I have the option and the difference in price was negligible. I don't think I would have gone adjustable if I had paid someone to do the suspension work.
Old 09-16-2017, 03:15 AM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Bit Meister
Pehlen's Avatar
+1 - I did the same. Not hard and learned more about the complete suspension. I went with Sway Away adjustable spring plates (and Elephant Racing poly-bronze all the way around). It's tedious, but not too hard to do your own "string" alignment with the aid of some simple laser levels from your favorite big box home improvement store.
Phil E - 1988 Carrera #frisierterwagen
Old 09-16-2017, 04:01 AM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
michael lang's Avatar
That would be my first question as well.
Mike
'89 CARRERA
#402
Old 09-17-2017, 04:39 AM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Flojo's Avatar
maybe because its an issue with the rubber bushing?
these rubbers normally are vulcanized and sold by porsche as one piece only.
no mechanic has fun removing the old rubber.
so he suggests the part as is.
Regards, Flo
79 SC - Frankfurt, Germany
visit me on www.facebook.com/911garage
Old 09-17-2017, 04:54 AM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
Eng-o-neer
Tremelune's Avatar
Making ride height changes in the rear is a real pain in the rear. If you have adjustable spring plates, it cuts the time and number of attempts down. I'm no pro mechanic, but I doubt they get it spot-on the first go around either, and I would expect a discount with adjustable plates. I don't think any mechanic would profit from you having adjustable spring plates unless he was selling them.
If they're coming off for other reasons...I'd replace them. I got mine from Elephant (just the splines) and they worked out well.
Old 09-17-2017, 05:56 PM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
That's right....I think you nailed it. The height adjustment in the rear is difficult and time consuming. There is some adjustability with the stock spring plates, but apparently not anywhere near as much than with the aftermarket adjustable spring plates out there. I think the comparison would be 1/2" with stock vs. 2" with aftermarket adjustable spring plates.
I have a set of 15's I am running right now, but I also have a set of 16's that I may want to go back to at some time. The thinking is, that if I have the adjustable spring plates, I will be able to do that myself without too much difficulty rather than having my mechanic reindex the torsion bars again.
Old 09-17-2017, 07:26 PM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
Elombard's Avatar
I was not under the impression that the aftermarket allowed that much adjustment? I have not played with them.
In any case once your suspension is close the stock adjustment should be plenty.
Remember, if you are adjusting the ride height you may need an alignment. Is that something you are comfortable doing in your garage?
Erik L.
Old 09-18-2017, 05:24 AM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
Flojo's Avatar
I have learned that whatsoever versions of springplate there are, the adjustment is just kinda finetuning (max 10mm up or down from zero). whereas you actually dont want to go that much, as it will change the rest of the wheel allignment in relation.
It is NOT made for the actual ride hight-setup that has to be done by setting the torsion bars right. The torsion bars have inside to ouside different toothing, which, by rotating, allows you to change ride hight up or down various inch.
this graph is in German, but you can guess the idea of the bars. you allways have to envisage the inner and outer toothing in relation to each other.
Regards, Flo
Old 09-18-2017, 06:05 AM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
