Experience with CDI+ from Classic Retrofit
Hi there
Our host sells a replacement CDI... called CDI+ from Classic Retrofit.
I have a 1981 911SC Targa (Japan delivery) that lacks a bit in the Ooompf-department and wanted to know if anybody had any experience with the proposed upgrade?
Has anybody done this? Is it a worthwhile upgrade?
Karl
Old 09-14-2017, 08:48 PM
Put one in my 69 race car - very happy with the product and backup from Jonny.
Rob
Old 09-14-2017, 10:38 PM
No experience with CDI+
But I did have a positive experience with the MSD Streetfire unit (250 USD from US) which was a fraction of the CDI+ price. Get a new blank plug end from one of the PP posters then you simply make it plug & play too. You can return to originality quickly.
Streetfire on a SC makes it easier to start and smoother performance below 3K. I live in a hilly area & this helped. Probably the CDI+ does this as well - but at a much higher price point.
There are interesting developments going on in Australia with performance improvements for CIS using programmable Digital fuel regulators. You keep all the main CIS components, which is important for originality and car value, but you can easily upgrade performance. These units would be inconspicuous and possibly cost less than CDI+.
Old 09-15-2017, 02:59 AM
Jonny H's Avatar
We have done some work on integrating the FrankenCIS system with CDI+ already. We hope to control the fuel pressure from CDI+ which will allow programmable fuel and ignition map. This will be gold for the CIS and Turbo guys. It's some way off but we have all the parts and a plan is forming.
One of the things to bear in mind when making comparisons between products, is that we regard CDI+ as a 'platform' and are always looking to improve. Features can mostly be implemented through firmware updates which are published on our website. Other products tend to be disposable with no update path.
www.classicretrofit.com
Old 09-15-2017, 01:40 PM
I have had Classic Retrofit's new CDI on my '72 911S with the factory MFI for about 6 months and it made marked improvement in both how the car starts and it's drive-ability. My emissions went down and the car pulls very hard to the redline with no issues. The tach signal is smooth, the rev limiter is simple to use, and it is truly a plug in factory looking replacement.
I have not used the special tuning features of the box yet, but I will tell you the customer support and engineering that went into this product is unmatched by other CDI box providers.
Old 09-15-2017, 08:31 PM
Turbonut
Raceboy's Avatar
That would be very cool feature and would justify price difference. TBH I did not know your CDI+is fully programmable, it is great benefit and if you could integrate fuel control via electronically controlled WUR it would actually allow CIS to be useful. It would not be comparable to EFI in many ways but much-much better than nothing.
Only problem I see is that many CIS systems have worn out mechanicals (in the fuel distributor) and it is not easy for the average mechanic to rebuild one.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 09-16-2017, 12:33 AM
Jonnie makes a great product..and supports it.
most good aftermarket cdi will be a good improvement
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 09-16-2017, 08:14 AM
Tags
911 sc , cdi , classic retrofit
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
