-   -   DME relay, easy fix? (http://forums.pelicanparts.com/porsche-911-technical-forum/970340-dme-relay-easy-fix.html)
Alex599 09-15-2017 12:59 PM
Hi guys,
I just tested a spare DME I received with the car when I bought it. It failed. Now, I fixed my fog light relay quite easily a few months ago. It was a connection clearance issue, fairly easy fix. I thought I'd check with my fellow Pelicans before I drop $100 on a new one. Is there an easy fix? What should I be looking for?
Thanks,
Alex
http://forums.pelicanparts.com/uploa...1505505552.JPG
JackkTheMackk 09-15-2017 01:04 PM
http://www.ftech9.com/new-products/911-ss
Purchase that DME relay. I have one of theirs in my 944 turbo with the pump prime. SSD relay will last forever.
Lyle O 09-15-2017 01:24 PM
^^^^Same for me...works great in my '87 911. I love the pump-prime feature.
MrBonus 09-15-2017 02:03 PM
Do you mean this one?
911 Solid-State Relay (Pump-Prime) — Focus 9 Technology, LLC
SpyderMike 09-15-2017 02:18 PM
it was an easy fix for me - bad solder joints. I reflowed them and it came back to life.
86 911 Targa 09-15-2017 02:51 PM
Dme
The very usual suspect......
Gerry
adias 09-15-2017 03:19 PM
That is interesting I have 2 questions though: How long does the fuel pump run when the ignition is turned on? Can the ignition be on for a while without burning the fuel pump?
Alex599 09-15-2017 03:35 PM
Thanks all,
I'll definitely go the ftech9 route if I can't fix mine. In the picture below, should the solder be bridged at the pen tip?
Thanks,
Alexhttp://forums.pelicanparts.com/uploa...1505514922.JPG
SpyderMike 09-15-2017 03:51 PM
Buzz that sucker out - pretty much it is two relays. Find that open. Here is a nice thread on the workings of the dual relay unit.
https://dorkiphus.net/porsche/showthread.php?t=16859
and yes, I believe that is bridged. Flip it over and look at the width of the metal landing there...
SpyderMike 09-15-2017 03:54 PM
by the way, this contact looks suspect (could be the photo though). I would reflow all solder joints and see how it works.
http://forums.pelicanparts.com/uploa...1505516059.jpg
JackkTheMackk 09-15-2017 04:01 PM
The prime only runs the pump for three seconds and then shuts off. It will not burn your pump up.
adias 09-15-2017 04:18 PM
That is good but follow-up question: if for some reason, while doing car maintenance, the ignition is turned on and off several times, minutes apart is there any chance that pump priming will stress something?
gtc 09-15-2017 04:53 PM
No
adias 09-15-2017 05:14 PM
Great! Thanks for posting the link to the FTech9 device, and the pump primer in particular.
Jack Stands 09-16-2017 07:11 AM
Would it make sense to fuse the power to the DME? Supposedly Porsche does not have the power to the DME fused.
86 911 Targa 09-16-2017 08:06 AM
Dme
According to my 1986 3.2 factory manual, the DME relay is not fused.
Don't know why?
Gerry
DanielDudley 09-16-2017 08:57 AM
It's a primary wire from the battery. It would have a fusible link if it was in a modern car. The fuel pump wire goes from the DME relay to the fuse box, and from there to the fuel pump.
I fixed my old DME, and then replaced it with the solid state unit. Because I can always hear the fuel pump run before I start the car, I know that both the relay and the pump are working. I like that.
Also, since it is considered a pretty good idea to have a spare relay, I use the old relay as my spare.
MrBonus 09-18-2017 07:43 AM
I just ordered one of the prime-pump relays. I've never had the DME relay fail but I have noticed that it takes a few seconds of the engine turning over to fire up the engine and I'm wondering if this will reduce the strain on the starter.
SpyderMike 09-18-2017 09:04 AM
I have read that the circuit needs to see a certain minimum rpm of the engine before turning on the fuel pump relay (I have read 200)...could be why you have to crank for a bit to get it started. The idea being they didn't want the fuel pump running without the engine running.
86 911 Targa 09-18-2017 12:35 PM
Thus, the reason for the flywheel sensors....
Gerry
