Banned
2.2E to 2.4S
It seems to me projects get bigger and bigger the further into them you get, so instead of rebuilding the 2.2 in the 70E i am restoring i have decided to purchase a 2.4 73S motor that according the owner was rebuilt 40k miles ago. I think what i will do is have a top end rebulid done on the motor. The alure of 190hp over the 155 froom the E was too much for me. Plus, i think i can squeeze 200hp with my webbers and ANSA exhaust. What am i going to need to complete this swap. I have a clutch kit from sachs for 72-73 911, wil this work with my 901 trans.
GAFB
Re: 2.2E to 2.4S
-I think you'll stand to lose around 10 hp going from MFI to the webers, but I'll probably start a war by saying that. I don't think you'll get more power out of the 2.4 without massaging the heads. -The 2.4S will have more power, but keep in mind that it is going to be a bit peakier than the E. If you are paying 2k for a long block plus a top end rebuild, you'll have just as much in the 2.4S as you would in the rebuilt 2.2E -I don't believe the clutches are compatible, but I am at work and don't have the parts guide in front of me. Anyone else welcome to weigh in here...
Several BMWs |
Banned
"its not the size of the ship, its the motion in the ocean"
GAFB
-Carrol Shelby
Several BMWs |
there's no replacement for displacement?
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
there's no replacement for displacement... except boost
- a 930 owner
In round figures those are your choices (excluding boost or nitrous). BTW - I'd be skeptical that your headers will provide any more HP then the stock heat exchangers which are really pretty good.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman Last edited by jluetjen; 02-04-2003 at 11:01 AM.. |
GAFB
duc, you'll see mid-year 911 owners backdating to early exhaust like you've got. It's hard to beat. One thing I'd suggest if you're running webers is to take your existing one-in two-out muffler and have it converted to a twin pipe sport exhaust, a la factory race cars of the early 70s. I'm having this job done on an old muffler right now, that muffler will go on my hotrod motor. Be careful going to aftermarket/mod exhaust with MFI. Search the archives. MFI likes a decent amount of exhaust backpressure to operate efficiently. Sounds like you're favoring webers, though. No problem there.
Several BMWs |
Banned
i just want to know what the swap entails, what parts beisides the engine do i need to mate the 2.4 to my 901?
Warren Hall Student
You need to put your 2.2 clutch and pressure plate on the 2.4 flywheel.
If I was putting the 2.4S in a 70'E I would opt for putting the 2.2E cams and MFI on the 2.4 motor. It's a better street setup. That 190HP is just a number that you'll rarely meet on a street car.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Banned
neither my E nor the S i am buying have the MFI.
Anyhow -- basically, the exhaust system has an increase or decrease in backpressure in a particular rev-range which the MFI hasn't "planned for". Keep in mind that an MFI system (unlike a CIS or metered EFI system) doesn't know how much air is going into (and out of) your engine. All it knows is that for a given throttle position/rev/temperature that it needs to deliver a certain amount of fuel. This is what the 3-D space cam controls. By changing the muffler to a sport muffler, the fuel requirements change and the engine won't be happy unless the 3-D space cam is changed to compensate. BTW - The same applies to megaphones too. Racing 911s as well as the 906E's used the sport mufflers or megaphones combined with MFI and they were perfectly happy - they just weren't using the same intake, exhausts and 3-D Space cams as street 911's.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman Last edited by jluetjen; 02-04-2003 at 01:33 PM.. |
Banned
im not going to be using MFI, i will be using webbers so i do not anticipate any issues there, i just wanted to know if swapping a 2.2 for a 2.4 was pretty straightforward
Warren Hall Student
Besides the clutch you'll also have to change the fuel pump to one for carbs. You can just install an inline filter from Pep Boys or what ever. It's much cheaper than using the a MFI filter. Other than that it's pretty straight foward. There may be some 14-pin issues but I doubt it. It won't hurt to check though.
Banned
the engine i have in the car now is a running webbers. 14 pin? What does that refer to ?
Warren Hall Student
I was refering to the 14-pin connector on the engine wiring harness. I looked briefly at the schematic for the 70' 911 and it is the same one for all models T,E and S so the wiring shouldn't be an issue. The carbed cars just omitted the speed switch and also didn't have the cold start setup the MFI cars had so there should be no issues electrically. The wiring harness for the 2.2 and 2.4 motors are virtually the same. Both used external voltage regulators.
Well I would check the numbers on the case and see if you can determine whether you really have an 2.4S motor and perhaps pull the carbs and check the port size. You might have T motor, but a dead giveaway will be the alloy jugs (cylinders). Aside from the clutch/flywheel setup, you probably will have little problem with the swap. On the left front side, is there a camshaft drive visible? Hopefully you have S cams but nothing is a given in the world of "rebuilt" motors. Do you know the pedigree of the rebuild? MM might be in the loop.... Before the swap, take off the valve covers and do a proper check of the valves and rocker shafts. Retorqueing the head might be prudent.
I did a 2.4T to 2.4S upgrade two years ago and love my motor. It is MFI and I have no real probs with the a two pipe sport muffler, at least I have not recognized them. Finding the MFI proper components was a bear. HTH
Bill '72 911T-2.4S MFI Vintage Racer(heart out), '80 911SC Weissach,'95.5 S6 Avant Wunderwagen & 2005 997 C2S new ride. Last edited by zotman72; 02-05-2003 at 06:03 AM.. |
Home of the Whopper
I haven't read all the posts so excuse me if I'm repeating something. And I know this wasn't your original question, but I feel the need to voice my opinion!
If you keep your 2.2E and put in a 2.4 crank and rods, that engine will blow away a 2.4S engine. I have (had) a 2.4E with 8.5 compression that eats up the 2.4S's. If you use 2.2E pistons, you'll have about 9:1 compression. You're going to rebuild either way, go the cheap route that gives a better, more powerful street engine. You can reuse most of your parts except maybe the dizzy. Good luck! BK
1968 912 coupe 1971 911E Targa rustbucket 1972 914 1.7 1987 924S |
