Question STOMP! 1st time around!
OK,
This is my first 'unknown'!
I have an intermittent loud ticking sound that is directly related to engine revolutions (i.e., when I press on the gas). It has NOTHING to do with speed!
This sound occurs once a week and it appears that it happens when I go uphill. It happens on the same freeway at the same location.
Any thoughts? Help!
Old 10-25-2001, 08:40 AM
Post
Pinging?? Is it a metalic noise? Try chevron premium and see if it goes away.
Joshua Harrison
Porsche owner at heart
Old 10-25-2001, 09:30 AM
Post
is it engine related, or something in the trans or suspension? CV joints do that. mostly under load. they come and go until they get real bad.
Old 10-25-2001, 11:05 AM
ClayMcguill's Avatar
Throwout bearing or pressure plate bolts?
Clay McGuill '66 912 My 912's restoration website, '97 Jeep Cherokee, '70 Ford Bronco My Bronco's rebuild site
Old 10-25-2001, 01:35 PM
Send a message via ICQ to fred hannah
Post
bad valve knocking under heavy load? just a thought, hope its nothing to serious.
Old 10-25-2001, 04:19 PM
Post
Update:
I checked suspension, cleaned all electrical connections (plus the ground) with no success.
Checked the coil resistance = fine!
Checked the timing = almost fine!
Checked RPM = almost fine.
Checked ignition wires resistance = fine.
So using my hands, I decided to use myself as the conductor to determine if I have spark plug ignition. I wanted to feel how thousands of volts feels like! And guess what..... [this paragraph was a joke!] Sorry for the dry humor!
Unplugged left bottom wire and inserted an "extra" old plug, grounded plug with jumpber cable, and started the car = spark existed.
Did same spark test to the left middle wire = spark existed.
Same with left top.
Same with right top.
Same with right middle.
Same with right bottom.
After 2 hours, I was all confused!
This time, I unplugged the 'actual' spark plug and redid the test. Left bottom = ok.
Left middle = Ok! Left top = Ok! Right top = OK! Right middle = ok! Right bottom = BAM!!!! No stinking spark!!!!!
Now I am so happy to have solved my problem. RPM and Timing is very consistent now.
I was kinda laughing because the last spark plug that I checked was the problem. Why cant I be the 'lucky joe' that when I check 6 things, I would be luckly enough to pull the first problem......not the last!
And BTW, with this experience, it would be my first and last time I would be buying SplitFire plugs. Physically, the bad plug looks good but obviously someting inside is broken. SplitFire now has 1 less customer.
BOSCH, YOUR CUSTOMER IS BACK!
[This message has been edited by cab83_750 (edited 10-28-2001).]
Old 10-28-2001, 04:52 PM
81Targa's Avatar
Post
Any thoughts? Help!
If I had that problem, I would of just taken a different road to where I was going. Goes to show you who the mechanic is and who isn't.
Roger
Old 10-28-2001, 07:42 PM
Team California
speeder's Avatar
Post
Definitely avoid the split-fires, they are poop. Right up there with cool-collars and curb-whiskers. Does not belong on Porsche.
Old 10-28-2001, 09:23 PM
You do not have permissi
john70t's Avatar
Post
Amen brother, and I'll add champion as well
Old 10-29-2001, 02:43 AM
