Pelican Parts Technical BBS
Pelican Parts Technical BBS (http://forums.pelicanparts.com/)
-   -   Which Magnaflow Muffler? (http://forums.pelicanparts.com/porsche-911-technical-forum/971087-magnaflow-muffler.html)
SpyderMike 09-21-2017 12:26 PM
I am in need of a muffler for my 1985 backdate project. It is a stock 3.2 with CAT. I want to try a Magnaflow if I can get it tucked up out of the way so it isn't really visible below the rear center panel. I am looking at one in and one out. Which model are people using?
Thanks!
midnight911 09-27-2017 02:32 PM
I have a 10436 resonator with 3.6 and sounds awesome.
SpyderMike 09-28-2017 08:53 AM
Interesting choice. How did you end up selecting that one?
midnight911 10-05-2017 01:50 PM
for space availability reasons...
Reiver 10-05-2017 05:01 PM
A muffler should be tuned to the motor....more noise/larger exhaust pipes does not equal better torque or HP except, possibly, at WOT.
Noisier muffler on a stock set up usually means the torque band just got moved north (peakier) from your sweet spot so you are actually slower.
A trade off ....if it is simply about noise or look then it is ok I suspect.
tdw28210 10-05-2017 05:43 PM
Magnaflow 14210
https://www.summitracing.com/parts/mpe-14210
This Dynomax works well too
https://www.summitracing.com/parts/WLK-17676/
SpyderMike 10-05-2017 07:48 PM
Thanks. I think I will experiment with the Magnaflow 14210 first and see how that goes.
A horse with no name 10-05-2017 10:19 PM
Maybe also try asking Jack Olson, as I believe that he also has run them for some time.
Pelican Parts Technical BBS - View Profile: Jack Olsen
Speed metal 10-05-2017 10:36 PM
I just installed the Magnaflow about 3 weeks ago. Good stuff
Sorry for the partial view. Sounds good;)
http://forums.pelicanparts.com/uploa...1507267993.jpg
Jack Olsen 10-05-2017 11:46 PM
I have 11386, which is 2-in/2-out with 2.5" diameter pipes. (The 2.25" one is 11385.) I have it lower than it needs to be, but I'm trying to use it as part of my underbody aero.
http://forums.pelicanparts.com/uploa...1507272333.jpg
midnight911 10-06-2017 09:09 AM
the said resonator arrangement...
https://www.youtube.com/embed/epVDjfSz3oM
midnight911 10-06-2017 09:14 AM
the said resonator...
https://lh3.googleusercontent.com/bK...o=w480-h360-no
SpyderMike 10-06-2017 11:19 AM
With a stock 3.2 with CAT under the backdated sheetmetal (which doesn't hang down as low as the later cars), I think I need one in one out on the same side. I will mock up the 14210 and see how it will fit.
Tremelune 10-06-2017 12:49 PM
Indeed. What are the goals here? If you want a louder exhaust, pull the rear seats and sound pad and save some weight...
ausgezeichnet 10-06-2017 01:29 PM
I used a Magnaflow 12265 for a 1 in 1 out conversion to a 1 in 2 out. Fits nice and sounds great
Driven97 10-06-2017 01:51 PM
Originally Posted by tdw28210 (Post 9764787)
This is what I have. Hangs slightly below the rear fascia. $68 though.
http://2.bp.blogspot.com/-N6QfTVjhU2...615_210420.jpg
SpyderMike 10-06-2017 02:39 PM
My original post:
"I am in need of a muffler for my 1985 backdate project. It is a stock 3.2 with CAT. I want to try a Magnaflow if I can get it tucked up out of the way so it isn't really visible below the rear center panel. I am looking at one in and one out. Which model are people using?"
I don't care if it is a bit louder and I do have my seats out and sound pad out.
SpyderMike 10-06-2017 02:40 PM
I think on a backdate that would be quite a bit more visible.
Tremelune 10-06-2017 03:48 PM
For decreased visibility I recommend black paint.
tdw28210 10-07-2017 04:59 AM
^^^^Agreed^^^ VHT rattle can paint works well. Carried at most FLAPS.
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website
