Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Which Magnaflow Muffler?
I am in need of a muffler for my 1985 backdate project. It is a stock 3.2 with CAT. I want to try a Magnaflow if I can get it tucked up out of the way so it isn't really visible below the rear center panel. I am looking at one in and one out. Which model are people using?
Thanks!
Old 09-21-2017, 11:26 AM
midnight911's Avatar
I have a 10436 resonator with 3.6 and sounds awesome.
1984 911 Carrera Coupe - 32C #73 - M64/05
1989 E30 325i 4dr
2004 E46 M3 Coupe - RIP
2006 Sienna 5dr - the hauler
2010 Cannondale Caffeine II - Lefty
Old 09-27-2017, 01:32 PM
Interesting choice. How did you end up selecting that one?
Old 09-28-2017, 07:53 AM
for space availability reasons...
1989 E30 325i 4dr
Old 10-05-2017, 12:50 PM
Reiver
Reiver's Avatar
A muffler should be tuned to the motor....more noise/larger exhaust pipes does not equal better torque or HP except, possibly, at WOT.
Noisier muffler on a stock set up usually means the torque band just got moved north (peakier) from your sweet spot so you are actually slower.
A trade off ....if it is simply about noise or look then it is ok I suspect.
De Oppresso Liber
Old 10-05-2017, 04:01 PM
Cars and Cappuccino
tdw28210's Avatar
Magnaflow 14210
https://www.summitracing.com/parts/mpe-14210
This Dynomax works well too
https://www.summitracing.com/parts/WLK-17676/
http://www.carsandcappuccino.com
1987 Cherryrot G50 Coupe
1985 Prussian Blau M491 Targa - 1 of 65 in the US
1977 Mexico Blue flared, 3.2, back date, sunroof-delete Coupe - in process.
1972 Black T coupe to Longhood Turbo R5 tribute car (someday)
Old 10-05-2017, 04:43 PM
Thanks. I think I will experiment with the Magnaflow 14210 first and see how that goes.
Old 10-05-2017, 06:48 PM
Dial 911
A horse with no name's Avatar
Maybe also try asking Jack Olson, as I believe that he also has run them for some time.
Pelican Parts Technical BBS - View Profile: Jack Olsen
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 10-05-2017, 09:19 PM
Speed Metal Army General
I just installed the Magnaflow about 3 weeks ago. Good stuff
Sorry for the partial view. Sounds good
Old 10-05-2017, 09:36 PM
Administrator
Jack Olsen's Avatar
I have 11386, which is 2-in/2-out with 2.5" diameter pipes. (The 2.25" one is 11385.) I have it lower than it needs to be, but I'm trying to use it as part of my underbody aero.
Old 10-05-2017, 10:46 PM
the said resonator arrangement...
https://www.youtube.com/embed/epVDjfSz3oM
1989 E30 325i 4dr
Old 10-06-2017, 08:09 AM
the said resonator...
1989 E30 325i 4dr
Old 10-06-2017, 08:14 AM
With a stock 3.2 with CAT under the backdated sheetmetal (which doesn't hang down as low as the later cars), I think I need one in one out on the same side. I will mock up the 14210 and see how it will fit.
Old 10-06-2017, 10:19 AM
Eng-o-neer
Tremelune's Avatar
Indeed. What are the goals here? If you want a louder exhaust, pull the rear seats and sound pad and save some weight...
Old 10-06-2017, 11:49 AM
ausgezeichnet's Avatar
I used a Magnaflow 12265 for a 1 in 1 out conversion to a 1 in 2 out. Fits nice and sounds great
Mike
'84 911 Carrera Coupe
'83 911 SC Coupe
Old 10-06-2017, 12:29 PM
Originally Posted by tdw28210 View Post
This is what I have. Hangs slightly below the rear fascia. $68 though.
Matt - 84 Carrera
Old 10-06-2017, 12:51 PM
My original post:
"I am in need of a muffler for my 1985 backdate project. It is a stock 3.2 with CAT. I want to try a Magnaflow if I can get it tucked up out of the way so it isn't really visible below the rear center panel. I am looking at one in and one out. Which model are people using?"
I don't care if it is a bit louder and I do have my seats out and sound pad out.
Old 10-06-2017, 01:39 PM
I think on a backdate that would be quite a bit more visible.
Old 10-06-2017, 01:40 PM
Eng-o-neer
Tremelune's Avatar
For decreased visibility I recommend black paint.
Old 10-06-2017, 02:48 PM
Cars and Cappuccino
tdw28210's Avatar
^^^^Agreed^^^ VHT rattle can paint works well. Carried at most FLAPS.
Old 10-07-2017, 03:59 AM
