CNC'd speaker grills
Working as a machinist in a prototype shop I'm always thinking of parts to make for myself in my spare time - but it never happens as once I've done a days work in the shop I really don't feel like doing the same thing in my spare time. Anyway for the first time in many years I actually made something for myself.
I was really tired of the cracked grills on the rear shelf and when I finally decided to replace the speakers which had totally deteriorated I though new grills where in order. Anyway here's the photos of the first part I've made for my car......who knows what I'll do next now I have this new found enthusiasm!!! For you techies out there, I machined on a Haas machining center, part drawn up and programmed using surfcam and machined in black polycarb. Front of speaker.
This shows the Porsche text I cut in.
And...A shot of the macine shop.
I hope you enjoyed these shots and I'm sure I'll take some more photos of other parts I make for the car. I have a variety of materials at hand from most plastics to aluminum, magnesium etc., so who knows what I'll cut next!!
Awesome job!
to another 87 coupe in SJ.
ßrandon |
DP935 member
Looks great Matt. Im currently learning CNC programming and we mostly are using an Okuma and Bridgeport mill. I have been trying to think of things to make in the machine shop in my spare time and so far making machinest tools and auto body dollies. We have a spanish EDM OSU I believe is the name and an Okuma lathe also but I haven't used them much yet.
Does the polycarb clog the machine? I was thinking of making some runs of delrin and other plastics but wasn't sure because we mostly machine steel or aluminum. Keep up the good work.
Porsche Slantnose M505 M506 group on Facebook. https://www.facebook.com/groups/719995181372494/ |
geez..that looks great! How about making a pair of 78/79 door speaker grilles!!
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
very nice
kycarguy - I had no problems with cutting plastics, but we have been doing so for years now. Our business in the bay area is mainly prototypes for the tech industries in the area and medical work. So we're always cutting new designs for cell phones, laptops, medical equipment etc. We cut ABS, polycarb, delrin, nylon, plexiglass, glass filled plastics etc etc. We also cut alot of aluminum and magnesium which is very popular now with the designers for pda's etc., stainless steel also for medical tools and small parts where corrosion is a problem. But cutting steel is not my favorite as we're not really set up for that. We also have a couple of regular bridgeports and a manual lathe, and an edm which has yet to be plugged in!!
Now for cutting plastics just try and keep your rpms down with a higher feed rate so you're removing an nice sized chip. For instance if I was using a 1/4 end mill I would run the cutter at maybe 6000 rpms and feed at around 40 - 60 inches/min depending on the detail. The great thing with plastics is that if you screw up your feeds and speeds the cutter will rarely break. What programming software are you using? I'm only really familiar with surfcam, and have never programmed just using g code! We do so much 3d work that that would just be insane. Anyway good luck with your work, I learn something new almost every day, screw something up big time once in a while!! Here's the web site for our company, which isn't a very good website I have to say.- prototypesplus.com |
Matt,
very nice! what about a 6x9 in billet aluminum??? would look freakin' cool with a black mesh grill!!!!!!!! |
I like your shoes, they're shiney!
Seriously, the speaker grill looks really nice.. Good job -Jasper
We're all in the gutter,but some of us are looking at the stars. -Oscar Wilde |
Jeeze Matt, your shop could be a Haas advertisement! Must be nice.
The grilles look great, very understated and factory looking. I'm sure you'll think of other things to machine now that you've been bitten by the bug. I started down the same path as you, and now have a small business selling a few Porsche parts. I use Keycreator and Mastercam, but learned first by manual programming, then on Surfcam. A few years ago, I got the boss to buy me a seat of Mastercam, but no 3D yet. I've been able to do some pretty convincing 3D "looking" stuff with only 2-1/2D, you just have to get a bit creative with design and programming. Your feeds and speeds for polycarb sound about like what I'd run, so either we both are doing something right, or neither one of us knows what the heck we're doing! Have you checked out Practical Machinist on the web? http://www.practicalmachinist.com/cgi-bin/ubbcgi/ultimatebb.cgi Like any BBS, there are some people who don't know what they're talking about, but some good info can be found, as well. Keep up the good work, Jim |
One I've Been Thinking of Getting Machined
At first I thought you re-invented the speaker grilll, then I saw the Porsche script. Coooool.
Here's a project that I have been trying to figure out how/where to get done. I want to remove the center counsel in my '83. I think it would look sharp if I had a leater shift boot held to the floor with a 1/4" to 1/2" thick aluminum wrap around base that screwed to the floor (metal just wide enough to fit around the base of the shift boot). I picture it being a rectangular ring approx. 1/2" wide, beveled sides with counter-sunk screw holes. I don't think it would be anything to difficult to make. Main issue would be making sure it mated up with the base of a common/standard shift boot. If inclined add that one to your list. Nice job, Gordo
Don "Gordo" Gordon '83 911SC Targa Last edited by Gordo2; 02-24-2006 at 11:40 PM.. |
DP935 member
Matt, We are learning Mastercam 9., Mastercam X and Esprit. We are also learning manual programming the G codes which is a real pain but I guess we need to know. I need to check out surfcam too if shops are using it.
We do break some bits cutting stainless and other steels, aluminum and they make a loud CHING...lol. Thanks for the link and thanks for the info on cutting plastics. I will have to give it a try.
Matt, I have an 83 911sc and I need a pair of the 4 X 6 rear speaker grills. Can I buy them from you.
Thanks, MIke equityr@aol.com |
Hey Matt, do you still make these?
As a "Haas Driver" for the last 30 years....Ya done good!
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
