SC to RSR Project contimues....Some suspension work
Made a lot of progress in a number of areas this week.
Shell is prepped and ready for the mock up. I have gone into painstaking detail on every area of this build. The initial plan, the acquisition of parts, the work. Every last detail has been planned to the last detail. I know there will be challenges along the way but things are coming together well so far. Here are a few more pics working on the suspension mock up.... I am interested in comments. Thanks http://forums.pelicanparts.com/uploa...1506184660.jpg http://forums.pelicanparts.com/uploa...1506184820.jpg http://forums.pelicanparts.com/uploa...1506184820.jpg http://forums.pelicanparts.com/uploa...1506184820.jpg http://forums.pelicanparts.com/uploa...1506184820.jpg http://forums.pelicanparts.com/uploa...1506184820.jpg |
Congratulations, lots of devotion to get to the steps seen in these pictures. Are you doing a centre oil cooler?
Looks very nice! Whose struts are you using?
Can't tell from the pictures: Do you have shock tower reinforcement welded in to support the rear coil-overs? |
I have a dumb question....
When you go to coilover... what do you do about the torsion tube hole? |
They will seal the hole so they won't fill up with dirt/water. |
Are you running 15's with the rsr front struts? Any chance that you can measure the spindle drop on these yellow Bilsteins? I have read they are 12mm "raised" over stock in contrast to to the old version green rsr struts that were 11mm. I can't find the information anywhere!
Don't forget to post more pictures as your car comes together. |
| All times are GMT -8. The time now is 10:30 PM. |
