-   -   82 SC RoW - Possible bad WUR (http://forums.pelicanparts.com/porsche-911-technical-forum/971739-82-sc-row-possible-bad-wur.html)
yahh 09-26-2017 12:12 PM
I'm having an issue with my 911sc. Ever since I've owned it (last few months) I've had surging idle on startup that evened out when the vehicle got warm. It shut off on me once during startup a few months ago. A few days ago, I went to start it and it wouldn't hold idle. When I hold the throttle it will stay running. We ran a few tests and here is what we have so far:
Smoke Test through airbox = Passed
CIS Fuel pressure = 5.3 Bar
WUR cold pressure = 1.3 bar 22c
Resistance on the heating element = 37 ohms
We are suspecting a bad WUR, does that sound correct?
Thanks!
boyt911sc 09-26-2017 02:34 PM
Identify your WUR......
What is the Bosch ID number on the WUR? Do you have a US or ROW spec motor? You might have the wrong WUR installed in your car (?). Keep us posted.
Tony
yahh 09-27-2017 01:24 PM
RoW - 089.
SkiVT 09-28-2017 09:00 AM
Describe your hunting in more detail. Idle around 1500 immediately at start and settling down to after a few minutes to 950 range is normal. Surging between those points or dropping to 400 and then coming back up isn't as normal. My 83 Euro tends to drop after 15 seconds to 400 if the AFR setting is on the lean side. It always returns to 950 range without touching the gas peddle. The drop is virtually eliminated when the AFR is a little richer. I have no surging or what I would think of as hunting at idle.
I believe your WUR pressure is in range assuming you had vacuum applied.
Bob Kontak 09-28-2017 04:00 PM
CCP s/b 1.7 bar minimum at 22C. System pressure a smidgen too high. Frankly, neither one bothers me too much if you transition to WCP in a few minutes.
37 ohms seems to be a high number but I don't know. I would think that would lean it out quicker if it's supposed to be 25-ish like the 090 US WUR.
Post your WCP numbers and when.
http://forums.pelicanparts.com/uploa...1506643186.jpg
yahh 10-16-2017 04:55 AM
Well, I went to start the car today and it started up, hunted for about 20 seconds, and started idling right at 900. Went to drive it and it decided to stall again as soon as I let off the gas pulling out of the lot. The car seems to be running REALLY rich solely based on the smell from the exhaust and I've ordered a wideband, but it still seems like its an issue with something failing. I just don't see why the car would just start running rich one day without anything being changed.
Bob Kontak 10-16-2017 05:40 AM
What was the temperature at your location? It was chilly in Ohio this morning. That can make the car run more rich.
yahh 10-16-2017 05:49 AM
1.3 Bar @22*c
1.6 Bar @30*c
System Pressure is 5.3bar.
It idles fine after it warms up but dies completely after blipping the throttle OR getting off of it in between lights. It also will try to die in between shifts when off the throttle.
yahh 10-16-2017 05:50 AM
It's had the same symptoms ranging from 60* up to 82-85* F
boyt911sc 10-16-2017 05:51 AM
Control fuel pressure data...........
Yahh,
When you get a chance, measure your cold control pressure versus time @ 30 sec. intervals:
a). Fuel pressure test without running the engine until the CCP stabilized to WCP.
b). Same fuel test with the engine running but do this in a different day. You want to do both tests when the engine is stone cold and note of the ambient temp.
Each test should not last more than 5 minutes from start. The data would sufficient to get a good picture of how your WUR works. If you have any question, just ask. Your CCP is out of spec. and the WCP could be too (?).
Tony
yahh 10-16-2017 06:50 AM
Originally Posted by boyt911sc (Post 9778062)
Yahh,
Tony
Hey Tony,
Thanks for reaching out. I haven't measured it in intervals but we did do cold/warmer engine temp:
1.3bar @ 10*c
1.6bar @ 30*c
Is this still something I should do?
Here is an updated troubleshooting report:
-Car was bought as non-running car form a customer of ours that brought it in yearly for SI and oil services. The car had maybe 150 miles added yearly.
-Tested the starter and found out the ignition switch was failing so we replaced it alongside the battery.
-Dropped motor to do a valve adjustment/ fix whatever oil leaks we could without rebuilding and found 5-6 broken headstuds.
-Broke the motor all the way down, new bearings, piston rings, all new seals, RSR cam seals, Supertec Head studs, VR gasket kit, and carrera hydraulic tensioners. The heads went off to the machine shop, checked, and new guides installed/valves ground.
-Set timing, drove the car daily with surging idle at warm up (summer temps in VA)
-The vehicle was running fine with a fluctuating idle for about 2k miles after top/bottom end refresh.
-Shut off once after starting about 1k miles in but started right up and ran.
-One day after a 3 mile trip to the grocery store, it started but wouldn't hold idle and immediately died.
-Brought it in and started troubleshooting
- Wouldn't hold idle, had to hold throttle and started measuring pressures
- After sitting overnight, the car started to hold idle after 30 seconds (nothing changed)
- Once throttle is applied and you let off the car immediately shuts off
WUR cold pressure = 1.3 bar 22*c
WUR warm pressure =1.6 bar at 30*c
Resistance on the heating element = 37 ohms ; Spec is 24 ohms
boyt911sc 10-16-2017 07:05 AM
WUR casting........
Yahh,
Take a good look at the top of your WUR and find out if you have:
a). "Germany".
b). "France"
c). Blank.
Keep us posted. Thanks.
Tony
yahh 10-16-2017 07:46 AM
Originally Posted by boyt911sc (Post 9778183)
Yahh,
a). "Germany".
b). "France"
c). Blank.
Tony
I can see the letters ECN without removing anything so it appears to be FRANCE.
Thanks!
Reiver 10-16-2017 07:56 AM
CIS Flowtech...give Larry a call. The only Bosch authorized WUR/Fuel head rebuilder in the US and gets the fine little parts no one sells.
If you buy a rebuilt one 99% chance he did it.
He rebuilt my 89 Euro WUR and now the CIS works as it should (euro AFR controlled by the wur).
No affiliation with Larry but he does great work.....the indy shop I go to in Phx send all of their Bosch stuff to him....never had a return.
yahh 10-16-2017 09:15 AM
Just did test A.
62*F
BAR Seconds
.8 0
1.1 30
1.4 60
1.5 90
1.7 120
1.8 150
1.9 180
2.0 210
2.1 240
2.2 270
2.25 300
2.3 330
2.35 360
2.4 390
2.42 420
2.5 450
2.5 480
boyt911sc 10-16-2017 09:48 AM
Test results.......
Originally Posted by yahh (Post 9778383)
Just did test A.
62*F
BAR Seconds
.8 0
1.1 30
1.4 60
1.5 90
1.7 120
1.8 150
1.9 180
2.0 210
2.1 240
2.2 270
2.25 300
2.3 330
2.35 360
2.4 390
2.42 420
2.5 450
2.5 480
Yahh,
The reason I asked about the markings on your WUR was to determine if you have "Germany @ 30 Ohms" or "France @ 36 Ohms". These are the average resistance values I find between these WUR's (G or F).
Next, is to gather the data for same test but with engine running. This initial data shows your WUR is working but out of calibration. Your next data would be totally different so do not be alarmed. Just collect and record data without prejudice. Thanks.
Tony
Dave Kost 10-16-2017 11:24 AM
I would set the CO and RPM to specs - anything else is just a guess. Sorry I don't know what the specs are for a 911 Euro SC- could be underside of engine lid or engine decal.
Reiver 10-16-2017 12:16 PM
Porsche Factory spec manual... 800-950 rpm... CO... 1. - 2.0 for 930-10 82/83
SkiVT 10-17-2017 02:57 AM
Just to confirm: are you applying vacuum to the wur for your pressure readings? The chart posted shows results with vacuum, I believe. Tony will help you solve it but the little details like this can make all the difference in troubleshooting.
Vereeken 10-17-2017 06:14 AM
Just did test A.
62*F
BAR Seconds
.8 0
1.1 30
1.4 60
1.5 90
1.7 120
1.8 150
1.9 180
2.0 210
2.1 240
2.2 270
2.25 300
2.3 330
2.35 360
2.4 390
2.42 420
2.5 450
2.5 480
This is a test result without VAC applied. It is a slow riser that is for sure. Also the max bar reached is too low. But that could be down to only applying 12 V or less.
The bimetal gets 13.X when the car is running and that could make a difference.
I would say that at 1.3 bar at 22 celcius with 37ohm resistance start-up should be fine for a 089. But if it climbs that slow you will sure stall when you lift the throttle.
See what the run test suggested by Tony tells us.
When a bimetal rises that slow usually the wire around the metal is still ok but the insulation has cracked.
http://forums.pelicanparts.com/uploa...1508249612.jpg
yahh 10-17-2017 09:04 AM
Originally Posted by boyt911sc (Post 9778437)
Yahh,
Tony
Here is the test from today 15*c, almost exactly 24 hours since the last test.
BAR Seconds
- 0
.75 30
1.4 60
1.7 90
1.9 120
2.1 150
2.3 180
2.5 210
2.6 240
2.75 270
2.95 300
3 330
3.1 360
3.2 390
3.25 420
3.3 450
3.4 480
3.4 510
3.4 540
3.4 570
A small blip of the throttle and the car idled pretty consistent at 1k. Large throttle blip ~5k RPM, it was idling from 600 to 1000rpm and felt like it wanted to stall.
yahh 10-17-2017 01:12 PM
That was without vacuum as the car wasn't running. Most recent one is with the car running.
boyt911sc 10-17-2017 02:03 PM
SkiVT,
I simplified the test procedure because I have the profiles for the WUR's without vacuum applied. A quick glance at his data tells me that the WUR is working but out of spec. I will get into the details after tabulating the fuel pressure data in psi.
Tony
SkiVT 10-17-2017 04:52 PM
Got it. I recall seeing the no vacuum pressures being .6 to .8 lower for the 089 wur which roughly agrees with the path Tony is on for you (wur working but out of spec).
yahh 10-19-2017 10:58 AM
I really appreciate the help everyone has given so far. You guys have been awesome!
Picture of the car!
http://i63.tinypic.com/10z23xg.jpg
boyt911sc 10-19-2017 05:40 PM
WUR evaluation........
Thanks!
Yahh,
Went over the fuel pressure data you collected and are these are my observation:
a). CCP (cold control pressure) is too low.
b). Is the CIS fuel pressure @ 5.3 bar the system pressure? If yes, this is out of spec. It should be between 4.5~5.2 bar.
c). WCP @ 3.4 bar is at the low end. Range is 3.4-~3.8 bar.
Recommendation:
a). The measured CCP is too low. Set it higher 1.8~ 2.0 bar @ 22°F.
b). Set system pressure within spec. (4.5~5.2 bar) or @ 4.9 bar.
c). Adjust the WCP between (3.4~3.8 bar) or @ 3.6 bar with vacuum applied.
The WUR is working just needs some minor calibration. System pressure is set at the fuel distributor. Keep us posted.
Tony
yahh 10-30-2017 10:38 AM
Originally Posted by boyt911sc (Post 9783358)
Yahh,
Recommendation:
Tony
Tony,
We removed a shim from the fuel distributor and now the pressure is perfect at 4.8, however, our CCP fell to .6 with the WUR unplugged. We adjusted the pressure to about 1.8-1.9 and shes running like a champ! Back to DD duty for her! Thanks guys.
yahh 11-01-2017 02:58 PM
Curse this car and its problems! I'm having an issue when I'm sitting at the light the cars rpm starts to rise slowly. Goes from the set idle and climbs. If I force it down by letting off the clutch and holding the brake it will go right back down. Any ideas?
SkiVT 11-01-2017 03:43 PM
AAR? My idle behaves a little like that until AAR fully warms to close off the extra air.
Vereeken 11-01-2017 10:46 PM
I am assuming your 089 WUR is still connected as it should and you have a thermal valve and euro type decel valve still connected to the vac system.
The AAR being still open is a possibility. Easy to test. Mind you they all allow a little air through even when fully closed.
But my guess is your decel valve is ruptured or the vac line for the brake booster has a hole in it.
I am going with the last option first. Usually it leaks at a connector at the underside of the car.
DanielDudley 11-02-2017 01:29 AM
If you sent it to him, he will test and calibrate it on the bench.
