500 Miles on Rebuild
I'm about to change the oil, adjust valves, and tighten head nuts per Wayne's book after the first 500 miles. This will happen again in another 500 miles and then the engine should be fully broken in and ready for regular service intervals.
My question is do I need to get a new valve cover gasket kit each time I do this? Or can I reuse the one on there with 500 miles on it? Sent from my iPhone using Tapatalk
Matt. 83 911SC 85.5 944 NA - Sold |
Hi, i have a question why are you doing 1000 miles service after only 500 miles?
Ivan and yes if the gasket is not damaged reuse it for now..also it depend what kind are you you using? |
Wayne's book recommends doing this after 500 miles and then again at 1000 miles on a rebuilt engine. Sent from my iPhone using Tapatalk
Ok i have never read that book;-)i just finished recently engine but i put on 1000 miles non stop.
Been doing it like this for 30 years. I guess everybody has it`s own ricks;-)I cannot tell you it is wrong, just wondering...for me in 500 miles is not long enough for everything to settle,that is all. Ivan |
