-   -   need help identifying these 3 wires... (http://forums.pelicanparts.com/porsche-911-technical-forum/971942-need-help-identifying-these-3-wires.html)
Trakrat 09-28-2017 02:45 PM
While taking apart everything to drop my motor, I noticed the 3 wires in the pics below seem to have been cut... no idea what they are.
Can someone help identify what these go to? This was obviously done by a PO.
http://forums.pelicanparts.com/uploa...1506635103.jpg
proporsche 09-28-2017 03:13 PM
Hi..the wires look like for a 3rd brake light ...
Ivan
Trakrat 09-28-2017 04:22 PM
Ivan
No... because I have the original 3rd brake light, and it works fine.
OldSpool87 09-28-2017 04:38 PM
Fourth brake light?
Trakrat 09-28-2017 05:22 PM
Originally Posted by OldSpool87 (Post 9755471)
Fourth brake light?
:confused:
Just an FYI... the wires are wrapped in the same gray loom as the wires that go to the ignition coil.
proporsche 09-29-2017 01:04 PM
trakrat..again, the black yellow is for brakes ,brown ground and the white goes to you licence plate light. Somebody cut it off....all the wires are wrapped originally to gray ....
Ivan
