MFI Fuel Pump Zims vs. Bosch
Does anyone have practical experience with running/using the Zims vs. the Bosch fuel pump for MFI?? I have a 2.2E and a stock Bosch fuel pump (mounted up front) that will need a rebuild before it all goes back in. I'm interested in your thoughts on either rebuilding my existing fuel pump or go with a Zims or comparable fuel pump.
Glenn From the Zim's site: Zims has come up with a solution to replace the very hard to find Bosch 0 580 970 001 (Porsche 901.608.105.00) MFI fuel pump.
Ditto...
I'd like to know the answer to your question, too. I'm guessing somebody out there has given Zim's alternative pump a try on their MFI 911. Any feedback?
Regards, Bill
Bill Waite Grand Rapids, MI --------------------- '65 356C '73 911E |
We'll find out in a few months when we plug the engine in...;-) I installed the Zims pump...so we will see.
Bump for an update. Just saw this while researching Zim's pumps. Curious of other feedback also.
Regards, Olin 1972 911T w/Carrera 3.0 - Light Yellow ![]() 1994 964 30 Jahre 911 - Viola metallic |
I am thinking about trying the Zim's pump out as well. I'll keep everyone posted.
Anthony '71 911E w/ MFI |
fuel pump
Did the Zim's pump work out? Kinda curious my pump is located in the rear of the car. Did you have to relocate it?
We have about 3 hours of run time on the Zims pump and so far and all is well. Plenty of pressure. The pump runs full time even after pressure is built.
The pump is located on the front cross member and is wired directly to the fuse panel off of the starter switch. |
Looks like a Pierburg unit.
Working fine for me, I recommend mounting it up front as its not really suitable for mounting in the original rear shoe location. I made it fit there but its fugly, I plan to move it forward as in the pictures above, strapped to the front cross member. Another possibility is to mount it at the rear in line with the fuel pipe exiting the centre tunnel out of sight above the gearbox cross member.
It is less noisy than the original Bosch, but it can still be heard. No markings on it that I can recall to identify it, but it looks like a common after market in line fuel pump. I now have 2 original Bosch pumps to recondition one day, meanwhile this pump is keeping me on the road at a reasonable price.
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
Smile you have a Porsche
I am running the zims pump on my 69 911E (MFI)
It seems to be working fine. I would like to install an original but after using the zims in a pinch I will hold off until the zoms stops working. |
Old thread, but how's the Sims pump running? My Bosch just erupted... thinking about the Sims or searching for an alternate option until I can get the original rebuilt...
thanks!
Rick Phillips 1972 T Targa MFI |
I've had a Zims pump for about 3 years now. No issues at all.
My correct MFI pump that was 'new' kept breaking and would not stay working regardless of being fixed. At around 1/3 or less price than an original pump its hard to go wrong with the Zims unit. It does not have a return line so that requires some imagination in the plumbing department.
Matthew - drove Nurburgring with wipers on and no rain 1969 911E SOLD ![]() 2002 996 Cabrio 1995 993 Carrera 4 SOLD 2004 Land Rover Discovery II G4 Edition (Sold )
thanks for this thread !!!
Thanks Mathew! I read the Zims installation instructions and it didn't sound too bad... what did you do with the return line?
Two years on and the Zim's pump is still working fine.
You still need the return line for the MFI filter assembly return feed. I deleted the T connection where the Bosch pump once connected. One less thing to leak.
