-   -   Oxygen sensor relay - discrepancies (http://forums.pelicanparts.com/porsche-911-technical-forum/972142-oxygen-sensor-relay-discrepancies.html)
flat6_911 09-30-2017 08:36 AM
Didn't want to bump a thread from 2003 so here goes;
Car started acting up so i checked my relay. As i suspected she was clicking on/off/on/off. The car ran like crap but when the relay clicked it ran okay.
I sourced a replacement from a local shop. It wasn't the VW factory relay, it was a bosch 0332019150. The diagram doesn't quite match the original relay.
Original;
https://uploads.tapatalk-cdn.com/201...d70ea29526.jpg
https://uploads.tapatalk-cdn.com/201...465f418259.jpg
The new bosch;
https://uploads.tapatalk-cdn.com/201...a541f3f184.jpg
The problem is that with the new bosch, the car doesn't want to idle. Keeps surging at idle. If i pull the relay, idle smooths out but the car runs like crap if i press the throttle.
With the bosch, i checked and FV does buzz if i lift the plunger in the airbox (with key on)
Has anyone tried the bosch relays? Only difference i see in the diagram is the 85 to 86. Do i really need to source a oem relay? Or is there something else wrong?
schoward 09-30-2017 12:02 PM
I think your place gave you the wrong relay. Pics below are of my glovebox spare Bosch I bought off pelican years ago which worked fine in my car for years. The diagram on mine looks like it matches your original but not your new one. Part numbers are different and the 85 and 86 are reversed it appears in the diagram.
http://forums.pelicanparts.com/uploa...1506797668.jpg
http://forums.pelicanparts.com/uploa...1506797768.jpg
dhanl82 09-30-2017 12:27 PM
Please see the attached info. At the very bottom of the link the 2 different relays are mentioned with the summation that they both will work - bottom line - they both power 87 and 87b as needed - the rest of the diagrams should also be helpful.
Keep in mind you will always have a little roughness at idle as the Lamda control system is constantly adjusting the mixture - based on its input from the o2 sensor - as it attempts to maintain the optimum fuel/ air ratio of 14.7 when in "closed loop" after the o2 sensor has warmed up.
911 CIS Primer - Lambda Electrics
flat6_911 09-30-2017 12:34 PM
Hmm that's weird the host sells this one? Which is still different from the original.
https://uploads.tapatalk-cdn.com/201...7139fc6220.jpg
Tried to find a VW original relay but they're NLA
Dave Kost 09-30-2017 12:55 PM
Per Mr. Walker......
The relay on the right is the correct relay.http://forums.pelicanparts.com/uploa...1506801321.jpg
dhanl82 09-30-2017 01:02 PM
Were you able to view the link with the wiring diagram that I sent you? If so, you will see that 87 powers your O2 control unit and 87B powers the frequency valve. Since your idle changes when you remove the relay and you stated that the frequency valve is working, this confirms the fact that the relay is working correctly. If you are experiencing large fluctuations at idle you may have a way too rich mixture, air leaks, or other issues.
I have an 82 Sc and have had to chase down a number of CIS issues but once it is set up correctly it is a good, relatively trouble free system.
Good luck.
flat6_911 10-01-2017 07:04 AM
Okay so with the "new relay" i get surging at idle. If i pull down on the plunger to lean things out, everything smoothens out.
I checked the new relay with multimeter;
87: 13.4v
87: 13.4v
86: 11.6v
85: 35.4 ? ( fluctuates with the surging)
30: 13.3v (thought this was supposed to be ground)
If i put the old relay in the car and force the "flapper" to connect (the one that keeps flicking on and off), the car will run great.
https://uploads.tapatalk-cdn.com/201...51cf5aa3f6.jpg
SCadaddle 10-01-2017 11:23 AM
http://forums.pelicanparts.com/porsche-911-technical-forum/741033-911sc-frequency-valve-problem.html
steely 10-01-2017 12:19 PM
87: 13.4v
87: 13.4v
86: 11.6v
Actually, pin 85 should be ground or close to it. What were the units of measure for the 35.4 you read, milli-volts (mV)?
Pin 30 is tied to fused power and that reads good - this power will be switched to both pin 87s if the relay is working.
You can refer to the schematic link dhanl82 provided and you'll get a great idea of what's going on.
I can't account for the surging and other symptoms you are experiencing however.
If you get a chance, do continuity on your relays (out of circuit) from 85 to 86, from 86 to 85, 30 to each 87/87a (open), and the 87's to themselves(short).
Bob Kontak 10-01-2017 12:57 PM
30 is not a ground. It is the power from the Lambda fuse.
This is a only mildly experienced layman talking so it's worth what you are paying for it.:D
85 is the ground for the electromagnet. 86 gets power from the fuel pump. From how I read the diagram, the fuel pump is engaged (i.e., air sensor lifted) , power is sent to the magnet and then your relay is "clicked on"
This part of the circuit controls engagement of the relay and that is it as far as I know. Flapper pulled in or not pulled in.
87, 87b should provide the magic the Lambda box does with respect to the freq valve if 30 is providing power. (Mind you 85 and 86 work first or the lambda side can't talk between the box and the f valve)
If you have to close the magnet manually there could be a breakdown in the fuel pump feed circuit? Including a poor ground.
That's it on my basics. See diagram below.
Just a touch more wind.,.....
If your system smooths out but no power or revving capability (maybe some little backfires, too when blipping) your freq valve is not getting power. The freq valve must be powered for the car to run decently even in open loop (O2 sensor unplugged). The relay must be engaged thru the fuel pump circuit as well.
I might be talking trash but it seems to make some sense that the relay is powered by the fuel pump. For safety reasons?
http://forums.pelicanparts.com/uploa...1506887788.jpg
Bob Kontak 10-01-2017 01:01 PM
Here is a better pin-out.
http://forums.pelicanparts.com/uploa...1506888088.jpg
Bob Kontak 10-01-2017 01:13 PM
Time overlap, Dan. Took me a while to post mine.
You have some nice practical checks.
gazzerr 10-01-2017 04:08 PM
If you disconnect the o2 sensor does it run better? Careful though that connector can be very brittle.
flat6_911 10-01-2017 06:56 PM
Thanks for all the replies, will look into this shortly.
o2 sensor is actually already disconnected. PO set the mixture with o2 disconnected
steely 10-01-2017 09:53 PM
Dude?!
So like, your O2 sensor is disconnected already?
steely 10-01-2017 10:04 PM
Hey Bob - np, besides, the better stuff takes a while and is worth waiting for.
I was wondering about those relays, but now I'm not so sure.
SmileWavy
gazzerr 10-02-2017 03:37 PM
Hmmm i'd check the engine harness connectors in the back of the engine compartment and at the front of fuse panel in the rear. Maybe you are getting an intermittent electrical issue. The old relay was clicking on and off?
steely 10-02-2017 05:47 PM
If I misunderstood, disregard me, but in case I didn't, you should have the O2 connected if you are trying to troubleshoot the OXS relay.
flat6_911 10-03-2017 02:29 PM
I checked the large connector for the engine harness near the strut tower in the back, seemed okay. I read that spreading the pins may help the contacts. might try this if nothing else works. Yes, the relay was clicking on and off consistently. If she clicked one way, everything ran smooth as it did before. the new relay is giving me rich conditions once engine is warmed up.
Steely I have my new o2 sensor disconnected. when I installed the new o2, the connector in the rear crumbled in pieces. I think PO set the mixture with no o2 sensor (or he thought it was connected but the connector was in pieces) I drove it for the past 3 years with no issues and o2 disconnected.
Bob Kontak 10-03-2017 02:48 PM
O2 input is not that critical. The freq valve MUST be working to give you the default duty cycle.
Another way to say it is if you are dialed in at idle w/o O2 input, your car can run fine at the expense of some fuel mileage.
That said, get the O2 sensor in the loop once you figure this problem out. You don't really piss away performance as the O2 is switched off at WOT, but when cruising, you ARE pissing away gasoline. These cars are pretty sweet when set up right per factory. 25+ mpg on the highway at a reasonable speed and when putting around, which is 90% of driving.
Bob Kontak 10-03-2017 02:52 PM
The steel female receptacle is still ok. Crumbling aside.
steely 10-03-2017 04:38 PM
I have an extremely limited level of experience with CIS, but I'm with Bob on this - I just think/suggest if you had everything together it would help in the troubleshooting dept (one less variable). What you think it running rough (during relay trials) may be the lambda ECU normal response trying to compensate for no O2 input. No disrespect intended.
My PO told me I didn't need the O2 sensor, but it turned out I had a completely different problem that made him think the O2/lambda was bad.
gazzerr 10-03-2017 04:50 PM
If you search you'll find the guy that sells a fix for the o2 connector. I think the lack of on o2 sensor signal just tells the jetronic brains to run in open loop mode the whole time. The other guys would know what happens if you run without the o2 sensor AND the relay.
This feels like an electrical issue. Maybe run some continuity tests between the relay wiring under the front seat pass and the connectors in the engine compartment? So tough when it's intermittent like that. It could be an electrical issue with the jetronic control box itself. Maybe someone could lend you a known good one and you could switch it out and see.
steely 10-03-2017 07:35 PM
The OXS relay gets power from the Fuel Pump relay (confirm me), so make sure the FP relay is sending power consistently by sticking a meter in the OXS relay socket (w/o harming pins) (86 hot to 85 rtn), and monitor, or try another relay.
If the power there is good, it's the relay. If not, and the FP is ok, it's the wiring or contacts.
Once that's working, is the FV working,whining? I think that is the only thing left to operate, even if you are ignoring the O2.
The oxs relay provides power to the FV and the ECU (buffers and handles the O2 sensor output, which might be being ignored).
Aside from some relay cartoon engravings, the relays you and others showed are essentially all good/the same. 85 and 86 may be flipped on the dwgs, but it is ok as long the relay itself is terminated to the correct pins. Pins 87, 87a, 87 b, should all be common to ea other (hence the measurement I asked you to do).
If the relay is bad, the FV will never get power (and either will the ECU).
Consider too if the OP tuned it w/o the O2 3+ years ago, maybe you're due for a check.
How quickly is the bad relay switching off/on? Not that it matters.
Getting colder up where your are? Let us know and good luck.
gazzerr 10-04-2017 07:28 AM
^^^^ this.
Bob Kontak 10-04-2017 12:20 PM
Yep. The lambda relay electromagnet gets it power from pin 30 on the FP relay. That's what I was rambling about in post #10 when we overlapped.
I think there may be a connection problem on the 86 or 85 side of the Lambda relay, primarily because OP can press the electromagnet together and all is well.
flat6_911 10-09-2017 04:33 PM
okay, I might of found the solution.
I work in isolated construction sites for long periods of time. I only get to drive and work on my car 1 weekend a month. I'm currently away but I've been reading old posts on the forums all week in preparation for when I get back.
I stumbled upon a old thread about a fellow pelican that was getting out-of-wack readings from the o2 sensor because the shielded wire was grounding with the middle wire of the harness. Not long after, I spot a more recent thread with someone that had the same issue.
I did mess with my o2 wire prior to this issue. I twisted the wires from the shielded green wire together and put a heat shrink to protect it incase I ever decide to run a o2 sensor again.
Could this be it? could the "shield wire" be giving the ECU some sort of reading from the "center wire" of the o2 harness? could I remove the wires at the ECU ? (pin 2 and 4?). I'm assuming it was giving the ECU a lean reading and the car was compensating with A LOT of fuel.
Cant wait to get back home and figure this out, its killing me
steely 10-10-2017 10:22 PM
Thanks BobSmileWavy
steely 10-10-2017 10:32 PM
Could this be it? ...
I think you could be on to something here.
Man I wish I had a schematic of that ECU.
guessing, I think the O2 sensor only ever sends (or its receiver only ever sees) a small voltage or nothing at all (floating input). Some ckts however are designed to withstand a shorted input, but some aren't. either way, you may have found the cause - please let us know when you get back and get a chance.
I don't know if you can disconnect at the ECU - probably yes - but I don't know if it is a simple connector or a solder termination. I would be inclined to save the original harness and just try dressing the unused O2 sensor end by making sure no wire strands were exposed. Your call of course.
flat6_911 10-13-2017 04:31 AM
SOLVED!
That's exactly what it was. The ground wire that's wrapped around the o2 signal wire were in contact with each other. I trimmed back the ground wire and heat shrinked it. All good now, runs even smoother with the new relay
Bob Kontak 10-13-2017 06:09 AM
Nice work!
steely 10-13-2017 10:34 AM
+1
cool
gazzerr 10-14-2017 05:26 PM
Awesome :).
flat6_911 10-14-2017 06:34 PM
Thanks for all the help [emoji2]
Sent from my iPad using Tapatalk Pro
