spedrcr's Avatar
Question for those with Targa Body Braces
Just curious if there is a consensus on the install of the body braces.
Once installed do you load force by pulling together? Pushing apart? Or just snug up and call it good?
Old 10-02-2017, 04:09 PM
Checked out
McLovin's Avatar
I have a set.
I tried all three of the methods you describe.
My set is now in the garage cabinet, because IMO all three are equally ineffective.
(Those bars as installed are practically vertical. No surprise they make no noticeable difference)
Old 10-02-2017, 08:26 PM
Cars and Cappuccino
tdw28210's Avatar
I think I jacked up the front end on each side and the tightened up when I first installed them. It's not like transformational change as the angle is pretty steep, but I like mine. I probably have snugged them once or twice in 5 years. YMMV.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 10-03-2017, 04:36 AM
Darkly-Noon's Avatar
I jacked up the side of my car a few inches using the jack socket in the rocker panel (not high enough to raise the wheels off the ground), and installed the braces. So when the car is back on the ground, the braces are in compression. As with the others, I could not detect a significant difference, though there seems to be less squeaking between the targa top and the front of the roll bar.
1980 911SC Targa
Old 10-03-2017, 05:54 AM
One thing I've noticed, with the bars installed, is that it's easier to open the doors when it's on the lift. Must contribute to the stiffness of the car to do that.
Tony
1973 914 2.2 FAT Black
1974 911 Targa Lime Green
2018 Macan GTS White
2019 Targa GTS Agate Grey
Old 10-03-2017, 06:35 AM
911tracker85's Avatar
I have a set on my 85 targa.
after installing I twisted them to lengthen them until pretty tight.
at best they reduce the shudder a bit.
now when I had a full cage in this car ... that stiffened it nicely.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 10-03-2017, 06:42 AM
spedrcr's Avatar
All of these ideas make some sense. I think I'll put on the targa top, raise the front of the car slightly and then install the bars to snug. If all I get is a reduction in shudder, no matter how slight, then its worth it to me.
Thanks all. I appreciate it.
Old 10-03-2017, 08:27 AM
I noticed a difference.
They should be in tension, not compression, per the instructions.
Old 10-03-2017, 09:22 AM
spedrcr's Avatar
Instructions? I didn't receive any instructions with my set. Do you have a set you can post please?
Old 10-04-2017, 05:44 AM
Nor did I, so a copy of the directions would be helpful.
David Yerkes
1987 911 Targa - GP White
Old 10-05-2017, 06:19 AM
