Externally Threaded Boge Strut - Gland Nuts
Is the gland nut that I require to fit Koni inserts into my late, externally threaded Boge struts the original gland nut off the strut assuming it had Boge inserts or a Koni specific gland nut?
I currently have Bilstein inserts and want to swap them out with Koni's.
Are the gland nuts and centering rings that I believe I also need available anywhere?
Rob
Old 10-29-2017, 05:40 PM
I would rather be driving
jpnovak's Avatar
Call Jason at Paragon Products. He will have what you need.
Old 10-29-2017, 06:30 PM
