Any Tips on tearing down and preparing for Sandblasting?
Hi Pelican Peeps,
I'm starting the tear down process and back dating a front date... on a 1972 T. Please see the pics below for the current state. I was wondering as I get closer what I should be doing? 1. What is the best/cheapest option to get the body on casters? 2. Do I need to remove the undercoating before I take it to get sandblasted? 3. I'm not planning on doing any welding/rust/hole repair until after sandblasting, is that okay, as I'm sure the sandblasting will reveal more issues. 4. It looks like it has a newer front clip, as there are bumper shocks, no battery boxes, but I can't tell where it was patched in? 5. Is there anything I shouldn't remove to get sand blasted? 6. I want to have the inside painted the same color as the outside. 7. It looks as if the doors may not be original either. 8. Still have to remove PO's subaru engine yuck and 915 tranny 9. So I guess I need to remove all of the suspension and brakes? 10. Is there anything I need to worry about getting ready for sand blasting, any suggestions? Thanks for all of your help, Rodney
Rodney Nelson - '72 911T (Undergoing Full Resto), '82 SC (Grand Prix White) Gone for 20 yrs and now back, '86 951 (Guards Red) Caught Fire, '71 911T (Tangerine) Sold, '72 911E (Grand Prix White) Sold, '86 951 (Black) Sold, '79 SC (Grand Prix White) Sold, '71 911T (Irish Green) Sold |
Vintage Owner
I think you need to remove everything that can be removed as the blasting sand gets into everything and will probably reveal all sorts of other issues you'll need to resolve. Getting leftover blasting media out is another adventure, though I wonder if the Dustless Blasting procedure would be any cleaner? Anyone have any personal experience with that procedure?
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Hi Jack,
Thank you for your input. Do you have any idea how you go about installing casters that I have been seeing people put on their cars before blasting so they don't have to have the wheels on? Thanks, Rodney
Vintage Owner
Folks seem to either use rotisseries (the best), or otherwise can construct a dolly out of metal pipes or wood to raise the chassis and have casters mounted to allow the chassis to be rolled around. Searching around should provide some pictures of what folks have fabricated.
Vintage Owner
Here's one example!
49willard
I am in the process of restoring a 190sl that I have owned for 40 years. Last winter I started a bare shell restoration starting with mounting on a rotisserie, manually removed all undercoat, sandblasted the bare shell, welded in some patch panels, primed and final painted underside and wheel wells. I thought at first that I would try to do the job without going on a rotisserie. Knowing what I know now, I would not do it without it being totally stripped and on a rotisserie. I managed to borrow one, however, I would buy one if I could not borrow or rent one. If you really want to go the sandblast route, for the reasons indicated above, you absolutely need to go to a bare shell. To do that you have a looong way to go with disassembly. Based on the pictures that you posted, I am not convinced that you should go the full blown disasembly route
Bill 1961 356B coupe-long gone! 1986 Grand Prix White Cabriolet Last edited by 49willard; 09-18-2017 at 06:23 AM.. |
I am very close to completely gutting my 78. windshield out and about to finish pulling the wiring harness and remove the dash.
getting a rotisserie.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold ![]() |
Are you sure you want to sandblast? You'll have sand coming out of the cracks for years to come. Can you just wire brush the rusted areas. Cut them out then Por-15?
What me speed? |
My car is about as far taken apart as possible. I find sand creeping out every morning.
What me speed? |
There are many threads about this and the seemingly overwhelming opinion is sand is a PITA. Soda blasting is another option to consider, I hear it cleans up easier.
If you get a rotisserie I'd strip it yourself. It's time over money and blasting will cost you $1000 and up. Although I've never had it done, I assume it's like everything....get what you pay for. Blasting can damage...warp metal... I've followed down to the metal builds and there is sooooo much that needs to comes off with blasting, why take it off if it's not completely necessary? You should be able to get to all the common trouble areas with a rotisserie and a grinder with wire brushes.
1983 SC - sold 2002 996 C4S - sold 1968 912 |
there Is different media out there. some removes metal, some does not..
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
my car is being dry ice media blasted as we speak. Only residue is paint dust and does not damage metal in any way. Chose this method to avoid sand or soda creating later issues
80SC (ex California) |
+1 what Mickey said. There needs to be absolutely nothing on the car.
I blasted my car and I've spent an outrageous amount of time removing sand and eight months of hammering, vacuuming, and coaxing the sand still keeps coming. I stripped the car down to bare metal on the entire exterior and most interior to avoid warpage. Blaster was careful and it still happened a little. I only spent $500 but I had manually done ninety percent of the job. Blasting lightly will not remove undercoating. Anything rubberized will just bounce the sand back in your face. You will have to cut open parts of car to remove sand. Otherwise it will collect moisture and make it rust more/faster. Blasting will only help you in areas that are difficult to reach. And then you're just making more work for yourself to remove the sand. This is before the car was blasted.
2001 986 S |
Even high end custom body shops that have clients spend $100,000+ on restorations... and they think I'm crazy when I tell them about it. How is it that this method isn't used exclusively???? If I had the capital, I'd start my own dry ice blasting business in the entire Midwest area!!
1987 Porsche 911 Carrera Coupe |
How many bowls do you need???? ![]() ![]() Are you in the bowl making business??
2001 986 S |
To get a dry ice blaster and everything you need, including the dry ice is about $10,000. And I'd bet once these custom rebuild/chop shops realize how much cleaner dry ice is, they'd ALL be falling over to get one in their own shop. I've seen the mess that a sand/media blaster creates... absolutely NUTS that anyone would choose this over dry ice. ![]()
A good dry ice set up will cost you a lot more than $10,000.
grateful user
Dont use sand, use this stuff called "black beauty". Its ground up coal slag and very jagged and abrasive. Just a simple pass with a rented comercial grade blaster take off everything, and will not get hot because you dont have to hold the nozzle in one place. Did my whole car myself in a couple of hr. I think I used around 10 bags, at 7.50 a bag.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
nope.... already looked into it. machine and dry ice was $10k.
