Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Leak down test on a 911...
I've had such great success with tech issues, I decided to wade in again. This gets filed under "a day late and a dollar short", but here goes...I bought this car impulsively on BaT, but, so far, I don't have buyer's regret. The shop that's looking at the defective alternator offered to do a leak down on the engine (yeah, I know, this should have been done BEFORE I bought the car!). They want $375, which I think is high.
I've done leak down testing before, and have the proper gauges and, of course, a compressor. My question is, is the pulley or flywheel marked off in equal thirds, so that I can easily find TDC for each cylinder and do this myself at home?
Thanx for answering another newbie question. steve
Old 10-05-2017, 04:03 PM
Work in Progress
Rich76_911s's Avatar
I don’t know the specifics on each pulley, but my 1987 930 has marks to indicate TDC on each cylinder. I’d assume they all have those markings.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 10-05-2017, 04:30 PM
Hi Steve,
My '77 has the pulley marked in thirds- little hard to see, but there.
Just a tip to make getting help easier, put a signature line at the bottom of your post with car info so people can quickly see what year and model you have; makes getting advice specific to your car.
Rutager West
Old 10-05-2017, 04:40 PM
Reiver
Reiver's Avatar
Yeah, I think that is high compared to what I've had done.
De Oppresso Liber
Old 10-05-2017, 05:30 PM
Functionista
manbridge 74's Avatar
Takes about 2hr, sometimes 3 if problems or more interpretation is needed.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 10-05-2017, 06:09 PM
proporsche's Avatar
Hi Steve..i do leak down test listening to my gauge .When you turn the engine it will whistle when you get to the point of measuring It is almost perfect every time i do it.
manbridge..why is it you think taking 2-3 hours to do??I do mine in 1 hour .remove the plugs insert the tool and spin the engine...by hand of course;-)
Ivan
Old 10-06-2017, 05:46 AM
It depends it can be a pita to do depending on the year. Have to remove the a/c compressor, the booster fan (if installed), the smog pump can be a pain, removing the spark plugs etc...Most shops these day's are getting $100 per hour this can easily be a 3 hour job.
Old 10-06-2017, 05:52 AM
proporsche's Avatar
hmm i guess you are right and the price went up these days....but Steve`s 911 is 1974 so easy to do.And 375 for a leak-down test is a little too overboard....
Ivan
Old 10-06-2017, 06:01 AM
Peter Zimmermann's Avatar
$375 for a leak down test...on a '74 911? Are you kidding me? One hour labor - tops! Put the engine on TDC, #1, remove the plug and get after it.
BTW; DO NOT remove the plug for the cylinder you're testing until AFTER the engine has been placed on TDC for that cylinder. I have documented why, in other posts, for this comment. Briefly, it prevents carbon debris, that might be on the tip of a plug, from falling down, landing on the exhaust valve seat, and holding the exhaust valve open (after the engine is turned to that cylinder) a tiny amount. This false reading can cause panic, engine tear downs, and valve jobs, all for no reason!
Keep the Shiny Side UP!
Pete Z.
Old 10-06-2017, 08:31 AM
proporsche's Avatar
Good point Peter about the plugs..
Ivan
Old 10-06-2017, 08:55 AM
I too, thought it was ridiculously high, especially with no AC, etc. to remove. thanx for the help. steve meltzer '74 Carrera (USA) new to me
Old 10-06-2017, 09:06 AM
arggh...i've always pulled all the plugs to make it easier to turn the engine over by hand. steve
Steve Meltzer
'74 Carrera New to me!
Old 10-06-2017, 09:15 AM
proporsche's Avatar
Steve don`t beat your self too much..it most likely your leak down test is fine.
Only after you would see any problems, you would have to take off the valve covers and hit the possibly bad cylinder ,on the rocker arm, with a rubber hammer .To try to take away the possible carbon....but
that is not your case....
Ivan
Old 10-06-2017, 09:40 AM
Thanx for the reassurance, Ivan. one could always do a compression test. probably not as good, but much easier. s
Steve Meltzer
Old 10-06-2017, 10:10 AM
I did not see that it was a 74 anywhere in his post. Easy 1 hr job.
Old 10-06-2017, 10:21 AM
proporsche's Avatar
gome..Steve has opened another post regarding his 1974 911 alternator regulator;-)
Ivan
Old 10-06-2017, 10:28 AM
proporsche's Avatar
Hi Steve..yup;-)
Old 10-06-2017, 10:29 AM
I'll keep you guys busy with a million queries! steve
Steve Meltzer
Old 10-06-2017, 10:33 AM
Ivan
Or, if you end up with 30% leakage on a couple of cylinders, do the fun thing. Take the car for a drive, at least a few miles, let it cool down, and re-test the bad cylinders only! Driving is always more fun than removing rocker covers!
Pete Z.
Old 10-06-2017, 12:30 PM
proporsche's Avatar
That is correct Peter ,but i would be already pist , to know there is a problem,because if there is a problem i could hear it without the testing;-)so i would not even drive it..but idea is good for peps who would not know what to listen to...;-)
ivan
Old 10-06-2017, 12:52 PM
