-   -   Door lock issue, Goes in lock, but open agin the next second. (http://forums.pelicanparts.com/porsche-911-technical-forum/972933-door-lock-issue-goes-lock-but-open-agin-next-second.html)
c-w203 10-06-2017 11:29 PM
After been working with a stuck power window yesterday on my 88 convertible, I got a problem with the door lock. Door lock was working just fine before I started with the window issue, but I had to remove the door trim to access window motor.
Now, I can`t look the door from inside (can`t move the knob at all). If I use the key/power lock from outside, door goes in lock, but pops open again after a second...
Thanks for all help
proporsche 10-07-2017 12:34 AM
Hi ..it is possible that your door handle micro switch ,on picture number 4, is not clipped into the door handle.
http://www.design911.com/uploads/dia..._04_804-06.jpg
Also look if the solenoid does not have disconnected the arm..with the boll joint on end ,number 6
Ivan
mo-mon 10-07-2017 05:29 AM
Try this first. Remove the top door trim & see if the lock works w/out the trim. If it works, you have to find the proper alignment of the top door trim- you do this via the two screws at the end of the trim (near the hinges).
Make sure the vertical lock rod can move freely up & down. Adjust & check.
This happened to me while working on a window problem too.
c-w203 10-09-2017 03:15 AM
I tried to disconnect the lever from the locking swivel, and the swiwel part are working ust fine.
Then I disconneced the arm on the locking solenoid and that part are also working just fine.
So then I`m left with the latch assembly itself.
I`m not able to move it at all into lock possition with the solenoid and indoor locking swivel disconnected, it`s like its mecanically stucked. Any ideas that kan help me out.
(by the way, it`s hard to access and work with the lock assembly..)
