Banned
wobbly wheel bearing
hi
what is the best way to press the hub into the rear wheel bearing. I used a halfshaft and ran the hub on with an impact.
The wheel is now very loose/wobbly and i dont wanna do this to the other side, so i am wondering what is the correct way to do this.
Kyle
71 911
Old 02-05-2003, 01:35 PM
Cool
never did that job,, sorry
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-06-2003, 03:17 AM
I just did both of mine. To keep lateral pressure down you need a backstop for the inner race of the bearing on the axle side of car. I made a simple tool for this job. Cost was about $4. I went to the hardware store an got 1)5/8" by 7" gal. bolt.2) 2 5/8 washers and 1 nut 3) a 5/8" ogee washer. I ground the edges of the ogee washer until in just slip into the backside of the control arm bearing cup and fit against the back of the bearing. I put washer on bolt, then ogee washer then inserted bolt trough bearing so that the threads are sticking out on wheel side. Put hub over bolt, put washer then nut on and tightened nut. A hand socket is what I used so i could go slow and make sure the hub was straight. With the ogee washer pushing from the back of the bearing and the hub from the front , there was no lateral forces on the bearing to damage it. It is much easier to do than to explain. Just a note, if you damageed the inner race of the bearing so that the wheel wobbles a lot, you need to replace the bearing again. I also had to do this on one side. Hence my "special tool". Good Luck.
69 911 2.3Ez
85 928S
Old 02-06-2003, 08:04 AM
RETIRED
Joe Bob's Avatar
Put it in the freezer overnight....slides right in.
Old 02-06-2003, 08:15 AM
Banned
thanks
i went over to NAPA today and got this tool called a hub tamer thay even had new bearings in stock
i will try the freezer thing tho
thanks all
Kyle
71 911
Old 02-06-2003, 10:09 PM
What is an ogee washer?
Jeff Parker
72T *Sold*
98 Neon R/T sedan, red
98 Neon R/T coupe, white
98 Neon R/T coupe, blue
Old 02-07-2003, 06:22 PM
