When adjusting torsion bar and ride height....
I was wondering what angle the axles should be at after adjusting the ride height for a 1977 Porsche 911. Is there a certain range of degrees that the axles should be at for example 10 to 15 degrees or anything like that?
Old 10-08-2017, 11:31 AM
Bill Verburg's Avatar
You should be fine at any ride height that can be achieved w/ a stockish suspension.
The greater the angle the more heat will be generated and the better th grease needs to be but for 911s it's generally not an issue
Bill Verburg
Old 10-08-2017, 01:35 PM
Thanks I appreciate the reply!
Old 10-09-2017, 12:08 PM
