Drop Light for Confined Spaces
While working on my sunroof I was wishing I had a drop light that would fit into the limited space available. So I made one, using an LED strip intended to replace fluorescents and a cheap extension cord.
http://forums.pelicanparts.com/uploa...1507680575.JPG http://forums.pelicanparts.com/uploa...1507680575.JPG That is a Forest Lighting T5-30. It is approximately one foot long. They also come in two, three, and four-foot lengths. |
This little guy is great. Hooks that pivot and spin on both side and also a magnet on one. Led and fully rechargeable. Gets amazing battery life.
https://uploads.tapatalk-cdn.com/201...5c91a27921.jpg Sent from my iPhone using Tapatalk |
Great tip
This is strange but it works so well. It's almost holiday time, Christmas lights are out in the stores. Find a LED string, the brightest you can find with the whitest color balance that you like. LEDs make little heat, shove them in a white plastic garbage bag, then shove it wherever you want, in any shape you want. Use some killer magnets to hold the bag where it works for you.
| All times are GMT -8. The time now is 07:32 AM. |
