-   -   Starting After Storage (http://forums.pelicanparts.com/porsche-911-technical-forum/97370-starting-after-storage.html)
North Coast Cab 02-07-2003 05:32 PM
So the P-car has been off the road for 3 months. Filled up the tank, added Stabil and put in fresh oil when ishe went in to storage. Tomorrow most of the projects will be concluded and I'd like to start the car to check a few things. Anything special I need to do before starting? The battery is charged and ready to go.
JG
dean 02-07-2003 07:34 PM
Make sure there is oil in the tank. Make sure you get oil pressure when you first start it (but you would do that every time you start any car). If you are really worried about getting oil pressure you could pull the fuel pump fuse and crank it till you get pressure. Mine hasn't run in a month and I will just start it like normal.
Doug E 02-07-2003 08:01 PM
Mine had been sitting for 2+ months when I fired her up last weekend. I just jumped in, turned the key and drove away.
