-   -   Trailering for the first time (http://forums.pelicanparts.com/porsche-911-technical-forum/973739-trailering-first-time.html)
Corvus Corvax 10-12-2017 07:45 PM
I think I have it figured out, all except for the tie-downs. Does someone have a quick lesson for me? One of the things I have learned is that some tie down hardware is too big to fit through Fuchs wheels.
But I sure could use some advice form those who have BTDT.
Bill Douglas 10-12-2017 08:06 PM
Another one to add; don't leave it in gear. :eek: The reason why is all the rocking backwards and forwards on the same spot wears the oil off the gears then it's metal to metal.
Corvus Corvax 10-12-2017 08:35 PM
That's one I hadn't heard before, but I like it.
jrsully 10-13-2017 04:31 AM
1 tip, be careful approaching off ramps from the highway. IT WILL take longer to slow down and some ramps have abrupt turns. Was "alerted" to this way back in my early trailering carrier
Bill Verburg 10-13-2017 06:20 AM
If tying through the wheels it's best to use single ended straps
Here you can see the usual direct hook ratchet w/ a snap hook on the other end(bottom) and 2 versions of thru the wheel straps.
http://forums.pelicanparts.com/uploa...1507899265.JPG
Many use the above method, a strap is fed through the wheel and then the snap hook fastens to both ends of the strap. The ratchet will then attach to the trailer.
A much simpler arrangement is to forego the snap hook, just have a ring(as seen on the thru the wheel strap ends) attached to one end of the strap. Now the dead end is fed thru the wheel through the ring then to the ratchet.
Be sure to have at least 3 or 4 wraps of the dead end at the ratchet end.
leave the car in neutral and apply the parking brake.
position the car on the trailer so that tongue weight is w/i the trucks load range. Once the proper position of the car on the trailer is determined permanent wheel stops will ensure future placement.
Wheel stop
http://forums.pelicanparts.com/uploa...1507900785.jpg
brcorp 10-13-2017 08:10 AM
+5 "...position the car on the trailer so that tongue weight is w/i the trucks load range...." This also includes any additional cargo (gas, tools, etc)
Last thing you want is trailer sway at 70 mph!!
flat6pilot 10-13-2017 10:02 AM
Originally Posted by Bill Verburg (Post 9774635)
+1 on MAC straps. Get the best you can.
mepstein 10-13-2017 11:27 AM
At our shop, I may tow 3-4 different cars a week. The wheel straps make it easy.
Anytime you tow, drive for 5-10 minutes, stop and recheck the straps.
If its raining, give yourself plenty of braking distance.
