gduke2010
Brake pedal
It seems that either my brake pedal is getting harder to push or my leg weaker. I'm wondering if I upgrade my master cylinder and booster would help? It's especially, hard to blip the throttle going into a corner and seemed easier a few years ago.
Grappler
Do some resistance training.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
Diss Member
The "upgrade" for the master cylinder is a larger cylinder that increases pedal effort.
Either you have a vacuum leak, a failing booster, a failing master that is binding, an issue with the pedal, or a perception issue.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
I had this issue and it was just the brake pedal binding up from age. Rebuilt pedal box with new bushings solved it. So check that before you dump $$ on new master cylinder or booster or both.
gduke2010
Thanks going to check it out this weekend
gduke2010
Went for a drive today and no problem with the brake pedal. i had difficulty blipping the throttle at first. Then realized my knee was wedged under the steering wheel. when I vacuumed the car this summer, I moved the seat forward and didn't move it all the way back. So, I moved the seat back to where it felt comfortable once again and the heal-toe felt comfortable.
