Hex head size for eccentric bolts rear trailing arm?
Any know the size of the hex head I need to prevent these eccentric bolts from turning as I loosen the nuts in the other side? They are bigger than anything I have and I want to buy just ine if I can. I assume metric.
Hopefully it’s the same for both these bolts. http://forums.pelicanparts.com/uploa...1508088211.jpg
Suspension alignment bolts.......
You will need a 12-mm Allen (hexagonal) wrench.
Tony |
Thanks! I love this board.
| All times are GMT -8. The time now is 11:13 AM. |
