-   -   Idle Help ASAP (http://forums.pelicanparts.com/porsche-911-technical-forum/97418-idle-help-asap.html)
North Coast Cab 02-08-2003 10:17 AM
Idle Help ASAP
Started car for 1st time in 3 months. Want to adjust idle but can't find the jumper diagram before adjusting idle screw. Can someone help?
JG
yelcab1 02-08-2003 10:46 AM
DME does not need adjustment. That said, you can still do it by removing the yellow cap (1/2" size) covering the idle screw and go at it. You will need some kind of CO meter to really make it accurate. Best leave it alone, or send it to a smog station for adjustment.
bell 02-08-2003 11:02 AM
what's the idle problem you're having that you want to adjust?
North Coast Cab 02-08-2003 01:58 PM
Seems a little low. I meant to do it last fall but never did.
JG
bell 02-08-2003 03:06 PM
have you checked your plugs? i had a similar problem last year.....installed new plugs and it idled perfectly again.
my .02
