If you search for LED tail lights by a user named Spoke, there is a detailed discussion of this situation. He incorporates a resistor into his LED brake lights to address this problem. An add-on resistor will also solve the problem, and he sells one. Or you can just go back to regular tungsten filament bulbs for the two rear brake lights.
Good luck, Dave |
I would think adding a resistor defeats the purpose of LED bulbs (a lower draw on the charging system). I guess it matters how much resistance you need to add...
Here's the Spoke custom LED panel thread: http://forums.pelicanparts.com/porsche-911-technical-forum/854989-led-brake-lights.html |
| All times are GMT -8. The time now is 02:30 AM. |
