LinkBack Thread Tools Rating: Thread Rating: 4 votes, 5.00 average.
Brando
quattrorunner's Avatar
Wow. this'll be good. But 325 hp..............come on Jim.
Turbo powa!
1977 911s. it's cool
Old 11-16-2017, 05:40 PM
Affirmative
Old 11-16-2017, 05:42 PM
I donít understand how this was accomplished truthfully
1. In between the panels is a rubbery like substance. Like glue or seam sealer. Makes it impossible to get clean welds. Splatters everywhere
2. Where the 3 seams come together the metal is super thin so you blow right through
The only effective way I have found is to turn wire speed up a little and heat down a little. Make a cold pass, grind flat. Turn heat up a bit and speed down, make like a medium pass. Then turn heat up and wire speed up and make a hot pass.
You have to build up enough material to work with
I COMPLETELY UNDERESTIMATED THIS JOB. It truly is ridiculous amounts of work
Old 11-16-2017, 05:47 PM
I would rather be driving
jpnovak's Avatar
Gas weld is your friend here. Burn out the crap with the torch, wire brush in a grinder and then weld proper.
Yes, multi-step process.
Looks great though.
72 911T project car. "Minne" - A tangy version of tangerine
classicautowerks.com - EFI conversion parts
Old 11-16-2017, 05:51 PM
Looks great though.
Yea I only weld with gas, I had a torch and wire wheels, but it wasnít really making it any better
Old 11-16-2017, 11:32 PM
Formerly known as Syzygy
Canada Kev's Avatar
Looks great though.
Originally Posted by jimtweet View Post
Yea I only weld with gas, I had a torch and wire wheels, but it wasn’t really making it any better
You only weld with gas? From earlier post about adjusting the wire speed, it sounds like you're using a MIG. Did you mean you're using gas with your MIG or torch welding? I think that JP meant to use a torch and rod to weld, not gas with your wire feed. Or maybe it's me that is misunderstanding.
Regardless, I've heard that removing the gutters is a real PITA. Looking good so far, though, even if it's a lot of work.
Kevin
Old 11-17-2017, 07:28 AM
Sorry, yes gas mig
Old 11-17-2017, 09:42 AM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
Sorry, yes gas mig
OK. I was wondering how you could have done that welding with an oxy-acetylene.
Nice documentation on drip rail removal. Not for the weak of heart.
What welder and wire are you using?
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-17-2017, 10:52 AM
Hilbilly Deluxe
emcon5's Avatar
Where did you get the wheels, and how much did you spend? Been dreaming about a set of Ruf wheels for years.
82 911SC Coupe
GTI Cup #43
Old 11-17-2017, 12:07 PM
So Iím told this is the ďunobtainable ď RUF part,...
Shift knob button. Stopped producing these years ago, this one was found in bottom of old parts bin
And RUF strut bar
Old 11-17-2017, 02:44 PM
Ryan H's Avatar
This is awesome!
2007 GT3
1982 911SC
1998 Integra Type R
Old 11-17-2017, 03:40 PM
asdfasf
Old 11-18-2017, 09:52 AM
lil motivation
https://www.youtube.com/watch?v=MzH_Y-ytRmI
Old 11-18-2017, 10:10 AM
Turbo Powered Snow Blower
Man, to anyone thinking of shaving rain gutters, I completely underestimated this job
I have heard this statement from every person that removed rain gutters.
Derrick
Old 11-18-2017, 04:37 PM
Canada Kev's Avatar
I hope Iím doing the RUF employee justice who was responsible for this work
Looks F'ing great!
Kevin
Old 11-18-2017, 05:03 PM
Itís literally pure insanity. I donít think itís something you can even put into words, as dumb as that sounds. You really need to experience it first hard to get the level of work, frustration, and detail
They say welding is something that is learned by hands on expierence, not classroom time. I think Iím getting my fill on this one.
I tried using a torch today to burn the seam sealer out and it really didnít help. As soon as you touch it with wire it just starts splattering everywhere
Old 11-18-2017, 05:07 PM
what makes it so difficult if I may ask? Is it the joint where three panels come together and thats where all the seam sealer comes in? Which is impossible to weld?
Old 11-18-2017, 05:12 PM
1. The metal is very thin.
2. Seam sealer / rubber makes impossible to get clean hot welds
Old 11-18-2017, 07:23 PM
Canada Kev's Avatar
After you ground your weld, it looks pretty good. You appear to have been able to get decent penetration and a reasonable weld in the end.
Kevin
Old 11-18-2017, 09:08 PM
Took break from gutters.
First, passenger side headlight bucket
Old 11-22-2017, 12:43 PM
