-   -   How to use Techron correctly? (http://forums.pelicanparts.com/porsche-911-technical-forum/97453-how-use-techron-correctly.html)
alf 02-08-2003 03:34 PM
Did a search on Techron and while i am convinced that this stuff works, there seems to be a wide variety of application methods. From dump it into an almost empty tank and drive like hell to just add it to the tank before an oil change.
How do you use it and have you had good results?
Would using Chevron gas regularly negate the use of Techron?
thanks
alf
TurboBert 02-08-2003 03:44 PM
I dump it into an empty tank and then fill it up and I've had great results.
I was having a hot start problem and was ready to replace the fuel pump check valve when I gave Techron a shot. My hot start problems went away with the frist tank.
I haven't been using Chevron gas; in Hawaii it's about 40 cents a gallon more expensive than the same octane gas at Costco.
Wil Ferch 02-08-2003 04:30 PM
Use the recommended amount depending upon the 12 oz or 20 oz size. I ususally go a bit overboard, 20 oz should work for a 1/2 tank for proper strength. Then repeat. Do this ideally before an oil change...not after.
---Wil Ferch
DANNOV 02-08-2003 05:04 PM
I don't understand why I constantly see warnings on this BBS about using Techtron before an oil change. What is the scoop on this poop! I have used Techtron on all my cars for years with no problem and I don't change my oil after using it. Sounds like an old wives tale to me. Does anyone have any concrete proof or is it all just a feeling that a shot of Techtron is no good for your oil?
Wil Ferch 02-08-2003 05:26 PM
I belive the caution stems from the fact that Techron is such a good solvent. If there is any chance of it getting into the oil via blowby or whatever, it's just listed as a general caution to be a better deal just before an oil change..."just to be safe".
In real life, I've not been too concerned in my normal every-day cars..and they're both approaching 200k miles...so I guess it didn't hurt.
---Wil Ferch
tobluforu 02-08-2003 05:38 PM
I think people only change the oil if they are using high concentrations of it. I dump a bottle at a little before a half tank and drive the car like hell for an hour. At this concentration, I'm not sure if it's all burning up.
Better safe I guess. Someone on this board did some testing I do believe.
pwd72s 02-08-2003 05:46 PM
Is Costco "gas" gasahol? Many states, especially if run by the liberals, give a substantial tax advantage to gasahol. Here ARCO brand gas is heavily laden with alcohol, and usually sells for 15-20 cents less than other brands. I chuckle, seeing folks lined up to buy at these stations, when actually they aren't saving much, since gasahol usually delivers 10-15% LESS gas mileage than straight gasoline.
nostatic 02-08-2003 06:58 PM
I do one 20oz bottle then fill the tank. When the tank is done, I change the oil. You can smell the stuff in the oil. While concentrations might be low, what does it hurt to just do Techron every 3K and dump the oil? I think any additives like that will affect the ability of the oil to do its job.
Targa Dude 02-08-2003 07:09 PM
Their are two Techron products out there, are you guys refering to the fuel additive or the fuel injector cleaner?
I only use the fule injector cleaner every other tank full.. seems to work fine for me and my Baby..
Jorge (Targa Dude)
alf 02-08-2003 07:53 PM
Referring to Techron Concentrate Fuel System Cleaner. They are $10 for a 20oz bottle.
thanks
speeder 02-09-2003 10:43 AM
I used the concentrate a couple of times before oil changes per the advice on this board and never really thought about why, now I'm wondering why. :confused:
20 oz. of anything disolved in a tank of gas would not make fuel wind up in oil if that were not already occuring, ie. a non-firing cylinder, etc. AND, it would have to be a non-firing cylinder due to lack of spark , not a plugged injector. That is the only way that "fuel wash" in cylinder happens, and it is a bad thing w/ straight gasoline, that's for sure.
SOOOOO........, if you have a normally good running engine /w good compression sealing, just throw a bottle of techron in when you feel like it and change your oil at normal intervals, IMO. Also, just using Chevron gas regularly will probably keep things pretty clean. :cool:
DANNOV 02-09-2003 12:19 PM
"I do one 20oz bottle then fill the tank. When the tank is done, I change the oil. You can smell the stuff in the oil."
Nostatic
I think you are smelling your own breath!
Sunroof 02-10-2003 02:23 PM
Techron is a petroleum distillate that does not combust. Based on the dilution of oil (it weeps down thru the rings and cleans the cylinder walls on the way to the oil pan) the oil must be changed within 500 miles of treatment. Porsche had a bulletin on Techron several years ago and providied the warning about the oil changes.
I have always heard and live by the best application a few times a year. Add 10-20 ounces to 1/4 tank gas, run and repeat.
Regards
Bob
73.5T
Superman 02-10-2003 02:30 PM
I use Chevron gas exclusively and do not add Techron. but I do know that Techron is good stuff, and that it is a nasty solvent that does not combust. Oil should be changed after use. If your injectors are clogged, put a whole bottle in when your tank is 1/4 or even lower. Drive a couple dozen miles and fill up, using another bottle of techron. Drive until the tank is about empty and then change oil. This clears most clogged injectors. B-12 Chemtool is good, too.
rstoll 02-10-2003 02:47 PM
I burn nothing but Chevron Premium in my 83 too. But I do use a bottle of Techron just before oil changes just to keep it clean. I add it at 1/4 tank and fill it up. Drive that tank out and change the oil. CIS likes it clean.
masraum 02-10-2003 03:10 PM
My '88 gets Chevron 93 all of the time, and from time to time I put some Techron in. Get the big bottle, I drink about 6 oz myself to keep things running tip top!
rstoll 02-10-2003 03:13 PM
Hey Steve, what do you use for a chaser??
nostatic 02-10-2003 03:18 PM
Nostatic
well, I didn't say I put the Techron in the tank...just that I do one bottle then fill the gas tank.
urp
Bob's Flat-Six 02-10-2003 03:48 PM
I've been thinking of adding Techron but haven't yet, but I do burn Chevron 90% of the time.
By the sounds of this thread it wouldn't hurt to add some before my next oil change?? I did have new injectors put in recently and noticed a big difference in power and just smoother running. want to take good care of my little squirters. I did see it at Costco.
Hey Nostatic did you make the SB run ??
nostatic 02-10-2003 05:38 PM
Didn't make the SB run...a little too nuts around our house these days. The wife is working 70 hour weeks and my son would have gotten carded at the winery :)
Hopefully the next one...
Bob's Flat-Six 02-10-2003 05:49 PM
I think I was the only SC 3.0 there, I coulda used Some help!!
chuckr 02-10-2003 07:15 PM
I have been using Redline injector cleaner in my 83SC. it has a valve lubricant additive that I like. I only use Chevron 93 in my car and I have new injectors. I have read so much on the inconsistancies of the gas refining process even with Chevron that I feel a good treatment is necessary for proper fuel system operation,especially in our older cars.
hilandscott 02-10-2003 08:52 PM
Different strategies?
When it comes to build-up perhaps the concentrated 20 oz. bottle to a near empty tank isn't the most effective.
It was recommended to me that a bottle in 20 gallons gives that much volume of cleaning, and more effective cleaning compared to only 50 miles or less of the conc. tank.
Just another 2 cents...
RoninLB 02-10-2003 08:58 PM
Re: Different strategies?
to my understanding.. the 20oz per tank is more effective if it's not a daly driver.. or only a short haul ride.. to give the Techron time to do its thing.. compared to a 300 mile ride
masraum 02-10-2003 09:54 PM
Marvel Mystery Oil!!
Goes down smooth and lubricates the innards!
:D
Sunroof 02-11-2003 05:57 AM
Ah, Marvel Mystery Oil....................
My mechanic said that I MUST use this stuff in my rebuilt 2.4 so I ran this up on the board this past summer and had a hell of a response from aircraft to snowmobile operators.
Although I use Chevron (gas and cleaner) I pour in 10 ounces of Marvel Mystery Oil in every third tank fill up. Great top end lubricant and fights moisture build up.
My buddy who runs a major maritime institute swears on this stuff for all marine engines. Heck, its been around since the 1920's, so something is working..................
Regards
Bob
73.5T
Porschedude 02-11-2003 06:14 AM
93 Octane! I want some! What is the problem with this stupid State of California! I filled up yesterday "Chevron 91 Octane" and the cost was $1.99 a gallon. It just keeps climbing and climbing. I think the county and the station owners are screwing us badly.
What are the rest of you paying for fuel? and what octane?
Keith
alf 02-17-2003 06:40 PM
Whodathunk, this Techron stuff actually works. I did 20oz in 3/4 tank and followed up with 20oz on 4/4 tank. 2/4 way through the second tank and the engine is running smoother (and it was not rough before this). Time for a valve adjustment and oil change next :)
alf
tight as a bull's ass 02-17-2003 07:27 PM
I have an idea.
Why don't you just read the instuctions on the bottle?
speeder 02-17-2003 07:47 PM
There you go. Smart as a bull's ass. :)
