-   -   What to do when CIS works perfectly? (http://forums.pelicanparts.com/porsche-911-technical-forum/974623-what-do-when-cis-works-perfectly.html)
RSBob 10-20-2017 05:23 PM
Fie on you good Kenik. ;)
For reasons unbeknownst yea I be in olde English mode, however since I most temporarily reside in Boston, where the British oppressors had their @$$e$ handed to them....
Reiver 10-20-2017 05:26 PM
Originally Posted by kenikh (Post 9784793)
Missed it was a Euro, so yes, good compression. Win! IIRC, large port was 78-79 only. Did Euros keep large ports?
Sent from my iPhone using Tapatalk Pro
Yes, in the 82-83 models.
Jonny H 10-21-2017 02:35 AM
Two options for ya:
240 BHP on CIS (hi comp pistons and cams)
http://forums.pelicanparts.com/porsche-911-technical-forum/972927-replacement-cdi-unit-6.html#post9784287
232 BHP on PMOs (no internal mods to engine required)
https://www.impactbumpers.com/forum/index.php?/topic/30521-30-sc-with-pmo-carbs-and-cdi-dyno-plot/
The CIS route will be more 'streetable' but the PMOs more shouty!
Litle brother 10-21-2017 03:31 AM
Originally Posted by Jonny H (Post 9785147)
Two options for ya:
PMO is also very streeable. My twin spark 3.2 short stroke puts out 283bhp and 345Nm with hot cams. It has a very flatt torque curve with 245Nm at the wheels at 2500rpm. and 293Nm at the wheels at 5180rpm.
Costs a lot to build, but WHAT AN ENGINE, real hot in a 1200kg targa [emoji4]
Tahttps://uploads.tapatalk-cdn.com/201...ed156418cc.jpg
Litle brother 10-21-2017 07:37 AM
Originally Posted by Reiver (Post 9784624)
Yes, that's what I have in mind along with a 964 cam.....yup
You could also use the 993SS camprofile. Gives even more grunt. Or you could "play" with advancing/retarding the 964 cam. One way gives more torque, the other more power.
Think the 993SS is the hottest one when using original pistons.
Reiver 10-21-2017 08:58 AM
Interesting options there....
I doubt I'd go back to carbs....FI throttle bodies would be more like it.
kenikh 10-21-2017 09:26 AM
993SS and GT2 cams are the only common plenum cams I like. 993SS is actually pretty great.
Jonny H 10-21-2017 09:29 AM
^^ No doubt , PMO twin plug SS motors and FI throttle bodies make a powerful motor.
My impression was the OP was looking for a slightly 'easier' upgrade path. Might be wrong though.
Reiver 10-21-2017 10:12 AM
No, you are correct...the rebuilt 930-10 I have is excellent and redone by a master builder...I use about 8-10oz of oil between 3k changes. With the SSI's/Dansk and the lightening I've done (2450 lbs with 20 gallons of fuel) it moves nicely.
What, estimate as set up 220hp as a guess.
What compression were you referring to Johhny as I've the 9.8-1 Euro now?
Litle brother 10-21-2017 10:25 AM
Of course Jonny [emoji4] my bad [emoji20]
Then I can sum up the spec on my previous build:
3.0 SC Euro with 9.8:1 cr and 39mm intake ports.
964 cam, lift 1.35 at TDC
46mm PMO ITB
Singelplug
Electromotive Full sequential ECU
SSI
This setup was dynoed to 253bhp and 290Nm. on a Dynapack.
[emoji4]
Reiver 10-21-2017 10:33 AM
46mm PMO ITB
Singelplug
Electromotive ECU
SSI
[emoji4]
Hey, appreciated your input...no 'bad' about it.
That run down looks pretty damn nice.....
Bob Kontak 10-21-2017 11:11 AM
Just arm chair talking. On my 81, Engine Builder's Supply cut 0.006" off the heads to facilitate a fresh face for the new seals.
I did the volume calcs and it added 0.2 compression to my 9.3:1. Maybe you have 10:1?
Reiver 10-21-2017 02:35 PM
No idea...I run 91 (only thing in Az) + an additive for higher octane and have never had an issue...but the engine does pull strongly from 3200...I'll call Howard up and ask about that...he did the work.
Bob Kontak 10-21-2017 02:43 PM
Just a data point. I don't know if 9.8 vs 10.0 means anything. Frankly, I kinda wish they would have shaved 0.012" off if there was no downside, save premium gas.
Guessing Howard knows a touch more than me. :D
Reiver 10-21-2017 04:51 PM
10 or close to it is the limit I'd say for 91....altho I do boost it as best I can....I had a 930-16 US 83 and you can def feel the dif in real terms.
