-   -   Spark Plug connector (http://forums.pelicanparts.com/porsche-911-technical-forum/974940-spark-plug-connector.html)
1ricardo 10-22-2017 04:19 PM
Dear Friends,
I have this 3.6 from a 1990 964 and the spark Plug connector on cylinder #1 exhaust side is damaged.
This cable is kindda expensive around U$120,00, but I notice that the spark plug connector itself is cheap around U$20,00
Question is:
It´s possible to change only the connector on this cable? I´m asking this because I was looking the cable closeli the other day and did not find a way to disassemble the connector from the cable
the last picture is just the way the connector is sold
Is there maybe some trick or a way to do it?
thanks for the help
http://forums.pelicanparts.com/uploa...1508714022.JPG
http://forums.pelicanparts.com/uploa...1508714022.jpg
fizeus 10-22-2017 04:37 PM
Can't you simply buy a new connector and 1mt of magnecor plug wire?
Anyway you can re weld ii if it is broken and reinsolate with a piece of good shrinkable insulator... Just measure, first cable impedence, and check after welding... It must be the same.
RobWeiss 10-22-2017 05:38 PM
The copper piece in your pic is threaded and unscrews from the plug connector.http://forums.pelicanparts.com/uploa...1508719076.JPG
1ricardo 10-24-2017 02:23 PM
Perfect Rob!
Thank you all for the help!
