-   -   Trunk light question (http://forums.pelicanparts.com/porsche-911-technical-forum/974966-trunk-light-question.html)
evan9eleven 10-24-2017 01:42 PM
[QUOTE=Canada Kev;9788337]Here's what mine looks like...
As always Kev, you take things to a higher level. Even a frunk light switch is so elegant. SmileWavy
Snitzler 10-24-2017 06:01 PM
As SpyderMike said...
I got rid of the front and back lights. Also pulled the interior light bulbs, I was working on the car and left the door open. Almost killed my Odyssey. They really don't work as well as a good led flashlight.
echecsqueen 10-27-2017 10:32 PM
ok today I stole Kevin's idea and mounted the switch in my Renncover
Love ir...simple and elegant solution
Since you say you are a newcomer like me, here are the exact instructions for putting in a switch
(please dont be insulted by the simplicity)
I used an on off type switch from amazon
https://www.amazon.com/gp/product/B01G821G6A/ref=oh_aui_detailpage_o06_s05?ie=UTF8&psc=1
I first inserted the switch into my red cover and locked it in
then I cut the black wire leading to the trunk light (there should be a brown and a black)
Inserted the switch into the black line - I soldered and shrink wrapped each solder
viola
shadowjack1 10-28-2017 04:50 AM
i did this just a few weeks ago. i was running down my batt with the bonnet open .
steve meltzer 10-28-2017 06:27 AM
viola
loved the "closer....viola" thought i was the only one who used that bastardization!
thanx so much for your help. steve
bugstrider 10-28-2017 08:02 AM
Ooooooohhhhh, squirrel!!!(inside joke)
Must do this to our's too. Will tap into the frunk light power to run these that will be tucked up and out of sight, but will provide additional light when needed.
https://uploads.tapatalk-cdn.com/201...174458686e.jpg
Cheers
echecsqueen 10-28-2017 07:08 PM
Cool! I just ordered some similar LED strips for my interior footwells for when I drop something on the floor in the dark. What were we talking about?
Oh yes - the switch. While I was cleaning up that job today I got distracted by my cover and redid the fasteners. I will post this project on my thread
Queen Customizes her 3.2
http://forums.pelicanparts.com/porsche-911-technical-forum/959649-queen-customizes-her-3-2-a-14.html
Canada Kev 10-28-2017 07:48 PM
Yeah, when you drop something on the floor, lets go with that... ;)
Are they purple and dimmable...? Did you also get a Marvin Gaye or Barry White CD at the same time?
<a href="https://www.youtube.com/watch?v=3j3okb3kuts">Marvin Gaye - Let's Get It On</a>
echecsqueen 10-28-2017 08:09 PM
That really made me laugh/ great memories - anyway, my car is accented in red not purple :)
Marvin Gaye cassette for my Blau...but I do like Barry also
RSBob 10-28-2017 08:12 PM
I would love like to see a creative solution for a LED or light above the ignition switch and not the illuminated key solution.
echecsqueen 10-28-2017 08:20 PM
http://forums.pelicanparts.com/uploa...1509247123.jpg
Canada Kev 10-28-2017 08:28 PM
That actually would be pretty simple. An LED could be mounted to the plastic surrounding the steering column, just ahead of the signal lever. Theres a nice flat spot on the lower half that seems to be pointing in the direction of the ignition switch. There's access to power behind the dash right there and it could be run from the door switch which is located nearby. It could be wired to come on with the door open or if you wanted to get all fancy, latch it on when the door opens and off with the ignition switch turning on.
Canada Kev 10-28-2017 08:34 PM
I know about your red interior bits (the woman I was seeing is an interior designer and freaked out a little when I told her what you were doing with that vintage fabric), but was just going from my memories of the '70s...
echecsqueen 10-28-2017 08:40 PM
Originally Posted by Canada Kev (Post 9794495)
That actually would be pretty simple. An LED could be mounted to the plastic surrounding the steering column, just ahead of the signal lever. Theres a nice flat spot on the lower half that seems to be pointing in the direction of the ignition switch. There's access to power behind the dash right there and it could be run from the door switch which is located nearby. It could be wired to come on with the door open or if you wanted to get all fancy, trigger it on with the door and closed with the ignition switch turning on.
nice idea!
Canada Kev 10-28-2017 08:53 PM
'Twas Rick's idea, I just thought of a way to make it work.
RSBob 10-28-2017 09:35 PM
Kevin, excellent suggestion. I have an extra LED I will wire in pointing to the switch. Your solution is far safer than drilling a hole above the ignition. I appreciate you giving me the credit, but the pure genius is crafting the solution.
echecsqueen 10-28-2017 09:41 PM
If you told her it was '65 vintage Fortuny I bet she did freak! I can't imagine a better use for it.
Canada Kev 10-28-2017 10:11 PM
Yep, told her it was Fortuny from the '60s. She asked if it was pillows you were using and went a little bit pale when I said you had a few yards. It was rather funny, but I like to shock people - kinda odd that way...
bugstrider 10-29-2017 01:04 PM
I think there should be a thread started with the title.....
"Flight of the Bumble Bee"
Could be on all the side details that get started when we all go in to fix one item only to get derailed onto a totally different item. lol.
Oh yeah, back to the LED interior lights. Actually "JoeBob" is the one who turned me into the LED strip lights for the interior footwells and the engine bay linked to an Independant switch. The idea recently resurfaced when including those for the frunk area too. Bright light n low power consumption = win win for our cars. Especially if one looks into the lighter smaller battery.
Cheers and happy Sunday
https://uploads.tapatalk-cdn.com/201...e4e82466f6.jpg
Today's frunk-space tool go-for.
juanbenae 10-29-2017 01:46 PM
someone said "elegance"?
http://forums.pelicanparts.com/uploa...1509309977.jpg
