Trunk light question
How does the trunk light extinguish? Now, maybe mine's defective, but I think it stays on all the time. Was gonna put my sister in there to check! (or, the ex). I don't see a mercury sort of thing, as I expected. The car is a '74 Carrera. thanx. steve
(i could put my i-phone in there on video and close the trunk, but I didn't think of it before I took the lamp out of the circuit). thanx
Steve Meltzer
'69 911E/bastard
Old 10-22-2017, 06:08 PM
Trunk or engine compartment?
In the trunk, there is a switch on the hinge between the bolts that pushes in when closed- you should be able to close the hood almost all the way and see it go off.
Rutager West
Old 10-22-2017, 06:17 PM
...and of course push it in by hand to see if the switch works.
Rutager West
Old 10-22-2017, 06:21 PM
Banned but not out, yet..
RSBob's Avatar
Rutager is right on the money
I keep my trunk (front trunk = frunk) light disconnected at all times just to prevent running down the battery since I keep the frunk open most of the time to discourage mice. But beware, the light you disconnect is full time power which might short if touched to ground, so if you chose to disconnect, completely shrink wrap it, or put an insulated connector on it, or if all else fails, wrap well with electrical tape.
Old 10-22-2017, 07:38 PM
Formerly known as Syzygy
Canada Kev's Avatar
I also wired a manual switch in series with the light so if I had the lid open for an extended period, I could turn it off manually.
Kevin
Old 10-22-2017, 07:47 PM
RSBob's Avatar
Great idea! I’m doing that tomorrow.
Old 10-22-2017, 08:00 PM
Spiderman
Jesse16's Avatar
That is a great simple idea ! I can see my light go out just before I push to latch. I tend to keep the lid down but not latched during storage or work sessions.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 10-23-2017, 07:17 AM
i think someone may have removed the switch as there is no such animal on my car. Weird has the light and housing look perfect. thanx again. s
Steve Meltzer
'69 911E/bastard
Old 10-23-2017, 09:04 AM
I agree- Mine also conveniently turns off when I lower the lid all the way down but don't latch it - this is very nice when I connect a battery tender, and can't latch the hood due to the wires, and I rest easy knowing the light is off.
1988 911 Carrera, M491 Cabriolet
2016 Cayenne
Old 10-23-2017, 11:19 AM
RSBob's Avatar
Since I use a Battery Butler and keep the frunk open most of the time, I wired in a switch like Kev suggested. The switch illuminates too as an extra measure.
Old 10-23-2017, 03:30 PM
Recently Disbanded
juanbenae's Avatar
saw a great, simple idea at the shop I frequent the other day. with the hood open a clothes pin is placed backwards using the finger press end to hold the switch closed.
Old 10-23-2017, 03:40 PM
Canada Kev's Avatar
Here's what mine looks like...
Kevin
Old 10-23-2017, 06:09 PM
echecsqueen's Avatar
Looks fantastic. I am stealing this idea- perfect
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 10-23-2017, 07:55 PM
OK, here's a shot of the trunk light (actually it's mounting orifice, as it's been removed until I figure out how to shut it off) and the wiring. NB: there's no pressure switch to extinguish the light...not sure where along the road it got the axe. I really like the idea of a manual "on/off" switch, so I could control this. I'm really a novice at this, so can someone give me a part number or specific info on where to find this (seemingly mundane) switch? I assume you'd want it in the ground circuit (Brown wire here) thanx steve
Steve Meltzer
'69 911E/bastard
Old 10-23-2017, 10:10 PM
OK, ^&*(&$@%*($@& I forgot the photo! s
Steve Meltzer
'69 911E/bastard
Old 10-23-2017, 10:12 PM
Canada Kev's Avatar
I got my switch at an electronic parts store. You can place the switch on the power or ground wire, it makes no difference electrically.
Kevin
Old 10-24-2017, 04:55 AM
thanx, Kevin. that's what i was thinkin'. steve
Steve Meltzer
'69 911E/bastard
Old 10-24-2017, 06:56 AM
tobluforu's Avatar
I set mine up using just a male/female connection. I cant tell you how many times I have needed a trunk light in the past 30 years, maybe 3 times.
Old 10-24-2017, 07:00 AM
yeah, not like it's a huge trunk and stuff's gonna get lost in there. s
Steve Meltzer
'69 911E/bastard
Old 10-24-2017, 07:42 AM
I got rid of my lights (in the front and the back) and just have a flashlight in the car.
Old 10-24-2017, 11:10 AM
