CEO CEO is offline
CEO's Avatar
Send a message via AIM to CEO
4.0 N/A 500hp 9000rpm Mezger by Williams F1
Williams F1
I need this!!!! and a winning lottery ticket
Beginning with the Mezger-designed Porsche 3.6L engine from the 1990 911, the resulting specification is as follows:
500HP
Four-valve cylinder heads
Engine speed range extended beyond 9,000 rpm
Dual-oil circuits
Cylinders and pistons with titanium con-rods
Aluminium throttle bodies with carbon fibre trumpets
Upper and lower injectors for improved performance
A carbon fibre air-box with active multi-stage resonator chamber for mid-range torque optimization
Inconel and titanium exhaust system optimized for thermal performance
CFD optimized and enlarged engine cooling fan
Ram air induction system with pressure recovery in intake plenums
Lightweight materials, including titanium, magnesium and carbon fibre are used extensively to reduce component mass and vehicle weight.
As ever, Singer’s work is motivated by the desire to understand the perspectives and requirements of its clients and to present them uniquely personal restoration and modification services - always guided by the philosophy: Everything is Important.
Kenneth
Silver 81' Targa
Old 08-09-2017, 09:14 AM
I want
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 08-09-2017, 09:18 AM
Elombard's Avatar
Look at that exhaust, I bet its OEM quiet but roars when you want and weighs half. Wow
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 08-09-2017, 10:30 AM
Some dude in Dubai just placed another order I'm sure.
Old 08-09-2017, 10:37 AM
Almost Banned Once
sc_rufctr's Avatar
Nice, Petrolicious has a page... https://petrolicious.com/articles/singer-williams-mezger-500hp-air-cooled-flat-sixes
- Peter
Old 08-09-2017, 10:40 AM
Swtbbyjsus
Matt - 84 Carrera
Old 08-09-2017, 11:12 AM
JamesUK
Anyone else notice the fender flare/ extension? Wide body Singer anyone?
Old 08-09-2017, 11:57 AM
Eng-o-neer
Tremelune's Avatar
What's up with the exhaust? Where's the muffler? Looks like it's...surrounded in muffler? Could really use one of those...
Old 08-09-2017, 12:01 PM
Eng-o-neer
Tremelune's Avatar
Looks like these images are just CGI renderings:
Singer and Williams Are Wildly Modifying a Porsche Flat-Six
Sure fooled me. I guess they'll reveal the car it's going in in September?
Old 08-09-2017, 12:13 PM
LJ851's Avatar
What kind of black magic are they using to tension that multi rib belt?
Old 08-09-2017, 01:52 PM
proporsche's Avatar
i like it ..........beautiful engineering..
Ivan
Old 08-09-2017, 02:16 PM
I did! One can hope for a 934 style singer!!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C
Old 08-09-2017, 02:21 PM
CMYK's Avatar
That intake system seems like a mighty complicated piece to pull off in a regular chassis. I wonder if this is also a preview of something else..?
Old 08-09-2017, 02:45 PM
sc sc is offline
sc's Avatar
Love the air intake via the side windows!
Old 08-09-2017, 02:56 PM
how many engine builders has Singer now partnered with? Cosworth, Ed Pink, Williams and ?????
Old 08-09-2017, 03:00 PM
sc sc is offline
sc's Avatar
Carbon Quarters...Hmmmmm.......
I wonder if it will have a Carbon Chassis like the New Ruf CTR
[QUOTE=CMY;9694130]That intake system seems like a mighty complicated piece to pull off in a regular chassis. I wonder if this is also a preview of something else..?
jamesjedi's Avatar
Four valves? Perhaps it is liquid cooled?
Not sure how they keep it cool.
I think the 935 had liquid cooled heads?
Old 08-09-2017, 03:37 PM
gtc gtc is offline
abides.
gtc's Avatar
They mentioned using a larger fan.
Graham
1984 Carrera Targa
Old 08-09-2017, 04:50 PM
jamesjedi's Avatar
I am by no means an expert - I think that there are cooling issues with four valves and air cooling. Probably more than what a large fan could do?
Old 08-09-2017, 04:53 PM
Elombard's Avatar
Yeah look at how much work went into the fan housing and sealing everything. I wonder if they are able to make it work with very careful design? Maybe modern oils help some how?
Old 08-09-2017, 04:57 PM
