New-ish 911SC Targa Owner
pampadori's Avatar
Carrera 3.0 top end differences from SC
I'm trying to learn what might have be different on the carrera 3.0 to allow the 7200 revs.
As I understand it, the cams were the same and the valve size too. Anything else that mad 7200 safe for this motor compared to an SC?
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 10-25-2017, 11:50 AM
Bill Verburg's Avatar
'76 & 77 C3 used the 2.7 crank and rods, same as the '72-73 911 2.4S & 911 2.7RS
Bill Verburg
Old 10-25-2017, 12:41 PM
Send a message via AIM to EPorsche
Bill,
What did that do? From what I'm hearing they used 95mm pistons?
'77 911S w/'81 3.0/MegaSquirt/MSD
'81 911SC stock
Old 10-25-2017, 12:58 PM
SC-targa's Avatar
I don't beleive any CIS engine was reving to 7200.
A Carrea RS 3.0, which had the old S cams and a plunger type fuel injection. It would rev to 7200.
I'm betting a Carrera 3.0 was redlined at 6300 like an SC.
Jerry
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 10-25-2017, 01:23 PM
Originally Posted by EPorsche View Post
Bill,
yes, they used 95mm pistons but w/ a 2.7 crank and rods and flywheel
max hp was 2000@6k
max revs was 6800+/200
The bottom end is lighter than that used in the '78 up 3.0 SC's
the 2.7 conrod bush is 25.99+/-1mm the SC 24.9+/-1mm
2.7 conrod bigend width is 23.75+/-5mm SC is 21.75+/5mm
2.7 conrod small end width is 25.01+/-1mm SC is 22.025+/.025mm
2.7 main bearings 56.990-56.971 SC 59.71-59.990
2.7 conrod 51.990-51.971 SC 54.971-54.990
Bill Verburg
Old 10-25-2017, 02:01 PM
Jerry
you would lose that bet
Bill Verburg
Old 10-25-2017, 02:02 PM
SC-targa's Avatar
Learn something new every day.
82 911SC Targa
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 10-25-2017, 08:55 PM
Inch by inch the Carrera 3.0 emerges as something unique versus its younger brother the SC. Thanks Bill!
Old 10-25-2017, 09:20 PM
IROC's Avatar
In youthful enthusiasm, I replaced my stock rev-limiting rotor in my '76 2.7 liter (bone stock engine) with a 7300 rpm rotor from an earlier car. I would hit the rev limit coming out of turn 7 at Road Atlanta.
Was it a good idea? Doubtful. Did it do any harm? Nope.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 10-26-2017, 04:02 AM
redline
Redline was 6800.Big difference was the crank weighed about 5 lbs.less so point A to B was quicker which is where most races are won.Ciao
Old 10-26-2017, 06:24 AM
5 pounds?! The crank weighed 5 pounds less? Wow that is impossible for me to comprehend!
Old 10-26-2017, 07:29 AM
pampadori's Avatar
Here is a pic of my 2.7L crank. notice the counterweights are thinner in addition to the smaller diameter journals.
Here is a 3.0 crank for comparo:
Thanks for the info Bill. I had seen 7200 mentioned elsewhere but I'll trust your 6800.
Old 10-26-2017, 08:25 AM
Someone here did a 3.2SS engine with the C3 block. That thing must just SCREAM.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 10-26-2017, 10:12 AM
Reiver
Reiver's Avatar
The Euro 930-10 SC is also rated at 6800 +/- 200 rpm....at least for the 82/83 model years.
De Oppresso Liber
Strength and Honor 5th Legion
Old 10-26-2017, 12:24 PM
correct
the interesting thing is the catless cars w/ that motor govern it w/ a distributor rotor which cuts the spark, just like the C3
the same year SCs which have cats govern the 6500+/- limit w/ a fuel pump cutoff
Bill Verburg
Old 10-26-2017, 02:47 PM
Funny everyone here seems to think a lighter crank enables higher revs?
Old 10-28-2017, 01:54 AM
Bland
unclebilly's Avatar
In my 2.7 with webers, mod40 cams, 9.8:1 pistons, RS advance curve, I run to 7300. I made this change so I wouldn't have to shift to 3rd in the hairpin at a track I used to race it. It was worth about 2 seconds for me.
Old 10-28-2017, 05:27 AM
Bland
unclebilly's Avatar
Bill - what direction does the rotor turn in a C3? Is it the same as a SC?
I guess I could just go check on my early Turbo 3.0
Old 10-28-2017, 05:29 AM
It rotates clockwise which would be opposite an SC motor
Old 10-28-2017, 06:02 AM
