Don't change the rear height until you add the rear bumper and decklid. The added weight will affect the rear ride height a bit. I agree with Tremelune that, to my eye, the front may be a bit low, and the rear a bit high (though a little rake is not bad). But install the rear bits first before you make a final determination.
'87 Carrera (3.4L)
'07 Boxter
Old 11-11-2017, 08:48 AM
3Ddesigns911's Avatar
Thanks for the tip Lyle, but I am changing the stock bumpers and going with FG RSR bumpers as well as a glass ducktail. Those are very light parts and I doubt that they will affect the suspension. Either way I have been browsing through some stance threads and I am pretty sure I need to drop the back down a notch. BTW the rear sway bar is not installed yet. We're too anxious to see the car drive after all the work, but that should not effect the height.
Old 11-11-2017, 10:00 AM
steely's Avatar
Nice work!! - it looked like fun and turned out terrific. Can't wait to see the tail and bumper.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 11-11-2017, 04:12 PM
Hello, I have a 86 Carrara and am in the process of redoing the suspension. Did you change the torsion bars, and if so what sizes did you use?
Old 11-11-2017, 07:15 PM
My car is an 87 with the G50 transmission. I believe your setup is different in the 86 car and 915 transmission, but to answer your question, I did not change anything I left the torsion and sway bars stock, but had the sway bar and spring plates and its parts powder coated. I also used the original style rubber bushings for the spring plate from Elephant Racing. For the sway bar I used original Porsche bushings and replaced all bolts and nuts with new ones.
BTW we also tried the URO rubber swaybar bushings but ended up buying the Porsche ones at the end. That's because although dimensionally the URO ones are identical, they use a harder rubber compound and we found they were just not pliable enough to work well.
I guess the only change from stock I made was I used Bilstein Sport shocks in the back vs the original Boge and while the control arm was out we replaced the rear control arm bushings and wheel bearings.
Speaking of torsion bars; we had to drill a hole on one of the caps to knock out the bar. Does anybody have a link for a rubber cap I can put on the end of the cap?
Old 11-11-2017, 07:39 PM
Kind of Blue
MrBonus's Avatar
I consider myself someone who keeps his cars fastidiously clean but this project puts me to shame. Great work and a great read.
1989 Porsche 911 Carrera Coupe - Baltic Blue
1967 Lotus Elan Coupe
2018 Toyota Tundra
Old 11-12-2017, 05:06 AM
JB Weld is what many people use to fill in the hole, if they had to make one to get out the torsion bar.
Rutager West
Old 11-12-2017, 06:54 AM
Thanks. I didn't think of JB weld.
Sent from my SM-N900V using Tapatalk
zK
3D Designs
87 911 Carrera targa RestoMod
Instagram#3DdesignsSD
Old 11-12-2017, 07:13 AM
rokemester's Avatar
Inspiring to a fellow 87 Targa owner. Your car deserves Fuchs.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
2016 BMW 328i
Old 11-12-2017, 12:32 PM
I am on the fence about the Fuchs. Originally I was leaning in that direction also, but I would prefer to have 17" wheels so that would make the Fuchs to be cast aftermarket wheels, and at that point I rather have the OEM Porsche turbo twist wheels.
I also find that these wheels really match the curves of the old 911... either way the jury is still out on this one, but they can be changed any time.
BTW I am also going to strip the targa bar and going for the brushed look and if I were to do the Fuchs I'd want those also polished. My theme is going to be all silver.
Old 11-12-2017, 01:31 PM
Thanks for the thoughts about the torsion bars. Speaking of the Targa bar, I was also thinking of stripping mine. I understand it is stainless steal. I do not know what grade. To get the brushed look it has to be evenly brushed, a la Delorean, which was very comlicated to repair and get the same brush look. There were even special brushes issued. Anyway I was just thinking of highly polishing mine. Have any listers done this to the Targa bar?
Old 11-12-2017, 06:19 PM
If you search the forum here you will find info about stripping and re-finishing the targa bar.
Here is a link with good info
Targa bar paint or strip for chrome look
This is what I am planning on doing also with brushed finish.
Old 11-13-2017, 07:13 PM
Ride Height Adjustment
Having the car down on all 4 I realized that the back was sitting way too high (measuring about 26.5" at the fender lip)
I did some research and learned about the 87-89 cars' torsion bars 47/46 tooth splines and how a 10 min angle change will result in a 1.4mm height adjustment at the wheel. Based on that I figured out the angle I need to increase my spring plate position.
After pulling the torsion bar and spring plate out, we noticed that the adjustable connection was already at the top setting (for the lowest ride) which I ignored when I had it apart before and powdercoated the 2 sections together hoping I don't need to change it. I realize now that was not the best idea, so we unbolted the adjustable sections and set it to the center so we have some fine tuning ability after the spring plate is installed at the new position. I added the extra angle that came from centering the bolt. (see picture below)
We pulled the other torsion bar and spring plate out next, unfortunately the eccentric height adjustment bolt was cross threaded when installed and it got stripped during unbolting which by the was was not easy to do.
Anyway, this is where it's at right now since I had to order the new eccentric bolt (from our host).
BTW, for those who wonder how much adjustability you can get from this link, I figure it's about 3/4" at the wheel.
On this picture you can see the marking where the spring plate is currently positioned, the line above is where I wanted to go and the extra wedge of tape indicates the adjustment for centering the spring plate eccentric bolt
zK
3D Designs
Old 11-26-2017, 10:00 AM
That Guy
Techno Duck's Avatar
The powdercoat on the threads of the adjustment bolts may be whats causing some grief getting them loose.
Total ride height adjustment using the eccentric is about 3/4 inch as you said, but this is from highest to lowest setting. Depending where its set initially you will probably get less.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 11-26-2017, 10:10 AM
Let me add another shameless plug for my T-shirt design.
I will be printing a few of these and started a "Taking orders" thread in the 911 parts for sale section. If you're interested pls respond through this link:
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/978767-taking-orders-engine-graphic-t-shirts.html
zK
3D Designs
Yes the powder coating made it hard on the one side, but that was not the case on the other side. I seriously have no idea how they managed to crossthread that on, but they did. I am surprised the bolt did not brake as we were taking it off. Had to use a long breaker bar with a pipe on as an extension.
Yes I guess I wasn't clear enough with my note. The adjustment is about 3/4" top to bottom.
zK
3D Designs
Old 11-26-2017, 10:14 AM
Stripping the targa bar
While waiting to get back to finishing to set up the ride height I thought I'd attack the targa bar. It had been painted glossy black, which is just wrong (IMO). I am not sure if I would have left it alone if it was the proper finish, but either way I want this car to be silver on silver on the outside, and since the targa bar is stainless to me that's a no brainer. I always thought it was a pain to clean that matte finish on my old targa anyway...
So here are a couple of progress shots.
These two show the bar in all of it's glory. Nice an shiny black.
Check out the beautifully painted targa badge. It appears this was done by trained monkeys.
After carefully peeling out the rubber seal from the channel, we removed the two nuts on either side in the fender well and unscrewed the top screws behind the rubber seal. You can see the screw holes on the front
Here is a shot showing the cover removed.
Started stripping the paint using this stuff.
I used aircraft paint stripper before, but it's not available at the hardware store now. Jasco paint stripper seems to work just as well. I also used a silicone spatula to scrape off the softened paint so I don't scratch up the metal, then washed it all off.
This is sort of where it's at right now. I got about half of the bar stripped, and did a bit of an experiment brushing it with a rough scotch pad. It seems to work pretty well. I'll update this when I get more done.
zK
3D Designs
Old 11-28-2017, 06:21 PM
rokemester's Avatar
You may want to check other recent Targa bar thread. Trying to match the brushed stainless look.
Old 11-29-2017, 12:29 PM
I did check it out, that's why it's not a trial and error. There are some good info here.
Here is a progress picture.
...and here it is showing the other side before. There is no contest IMO
zK
3D Designs
Old 11-29-2017, 12:48 PM
Your thread, hard work, and devotion is inspiring.
Great job.
Old 11-29-2017, 01:39 PM
