good used $100 911 speedo i got today.
Jeremy Brooks AKA VWLOOSENUTS
www.vwloosenuts.com
http://forums.pelicanparts.com/porsche-911-technical-forum/975822-my-912e-build.html
Old 03-08-2018, 05:04 PM
Some of the new panels are starting to show up.
So excited
www.vwloosenuts.com
Old 03-13-2018, 05:36 PM
Smile
Spent some time today measuring and checking and more measuring. Then checking some more.
Then some cutting.
So far everything lines up nicely.
www.vwloosenuts.com
Old 03-18-2018, 06:09 PM
Jeremy-consider removing the fuel injection control box and fitting an oil tank to the hole before you attach the fender.
Old 03-19-2018, 04:35 AM
Wouldn't I need to running all the oil cooler lines and the cooler up front to then.
I'm still running the 912E (style) motor but no EFI anymore just carb set up.
www.vwloosenuts.com
Old 03-19-2018, 06:43 AM
I thought I read earlier in this thread that you bought a 6 cyl mill. For that, you will need an oil tank and related plumbing. I you keep the 912e engine-you have to leave it as is.
If you go with the 6, you should evaluate whether you will need the upfront cooling system-it depends on whether you have a hot running engine, or if your driving environment is hot.
I am about to swap for a 912e that I will put a mild 3.0 in. For that, I am definitely going to have front cooling.
Old 03-19-2018, 04:48 PM
I see why you comment that way. I ended up just keeping the type 4 motor for it
www.vwloosenuts.com
Old 03-19-2018, 07:33 PM
coming along nicely!
Old 03-21-2018, 04:50 AM
Flojo's Avatar
and no worry. there are 4c engines running 200hp nowadays
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
https://www.instagram.com/spadescustomz_/
https://www.instagram.com/911garage_germany/
https://www.facebook.com/911garage
Old 03-21-2018, 05:22 AM
Thank you. Slowly but surely.
www.vwloosenuts.com
Old 03-21-2018, 06:46 AM
this is very true. I do plan to do some upgrading to the motor.
www.vwloosenuts.com
Old 03-21-2018, 06:47 AM
Flojo's Avatar
260hp...
https://www.facebook.com/MPSEngineering/videos/2372822352743902/
Old 03-23-2018, 04:18 AM
soooo nice..
www.vwloosenuts.com
Old 03-23-2018, 06:47 AM
Home of the Whopper
BK911's Avatar
What did you decide to do about the transaxle?
'71 911E Targa rustbucket
Old 03-23-2018, 08:22 AM
Iím using the 1969 902/16 transmission.
www.vwloosenuts.com
Old 03-23-2018, 06:18 PM
Worked on this lower corner tonight.
www.vwloosenuts.com
Old 03-23-2018, 09:41 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Is that engine lid 6mm too long or is it an optical illusion?
Gary R.
Old 03-24-2018, 06:26 AM
[QUOTE=GaryR;9973609]Is that engine lid 6mm too long or is it an optical illusion
All the panels are still just mocked up and sitting there. Nothing is in its final place yet
www.vwloosenuts.com
Old 03-24-2018, 07:43 AM
GaryR's Avatar
Gary R.
Old 03-24-2018, 07:44 AM
Got all the panels lined up and ready to weld on Permanently.
Kinda nervous to do so though Hahah
www.vwloosenuts.com
Old 03-24-2018, 12:19 PM
