Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Started in on the driver side
Jeremy Brooks AKA VWLOOSENUTS
www.vwloosenuts.com
http://forums.pelicanparts.com/porsche-911-technical-forum/975822-my-912e-build.html
Old 04-14-2018, 06:19 PM
  Pelican Parts Technical Article Directory    Reply With Quote #141 (permalink)
Trying to complete the drivers side today
www.vwloosenuts.com
Old 04-15-2018, 01:40 PM
  Pelican Parts Technical Article Directory    Reply With Quote #142 (permalink)
911T '72
DeRRis's Avatar
Great work. Again Why did you use the lens housing/rear bit from the yellow narrow body sheetmetal. Is of different to the SC?
Dennis
Good drivers have dead flies on the side windows. (Walter RŲhrl)
Old 04-16-2018, 08:52 AM
  Pelican Parts Technical Article Directory    Reply With Quote #143 (permalink)
Originally Posted by DeRRis View Post
Great work. Again 8) Why did you use the lens housing/rear bit from the yellow narrow body sheetmetal. Is of different to the SC?
thanks. the flare section was missing that part sadly.
www.vwloosenuts.com
Old 04-16-2018, 08:54 AM
  Pelican Parts Technical Article Directory    Reply With Quote #144 (permalink)
Interesting how you chose this line, going up the door jamb and along the quarter window to splice the flare in.
Is a line like this easier to match / fit than a round line that follows the outside of the flare?
Sent from my iPhone using Tapatalk Pro
Old 04-17-2018, 07:53 AM
  Pelican Parts Technical Article Directory    Reply With Quote #145 (permalink)
Doing the other side, the round flare weld wasn't the easiest for me. figured this time I would do it this way as part of the weld will be hidden under the quarter window and the vertical weld was more on the flat panel section.
Still learning this whole auto metal working part. I'm pretty new at it and I'm sure some professionals are reading this tread shaking their heads at the whys and how comes I'm doing the way I am. but they learned how to do it from trial and error also.
www.vwloosenuts.com
Old 04-17-2018, 01:15 PM
  Pelican Parts Technical Article Directory    Reply With Quote #146 (permalink)
Youíve got a lot more experience than me WRT panel welding. Iím just trying to understand some of your thought processes so I can learn.
Iím OK at fabricating parts, tubing etc., but Iíve only welded in a panel once, and that was by cutting out the old spot welds and welding in the panel on the old spot weld holes.
Old 04-17-2018, 01:22 PM
  Pelican Parts Technical Article Directory    Reply With Quote #147 (permalink)
I hear ya.
Sometimes I wonder about my thought processes myself hahaha. next time I will go all the way to the door jam instead of the long vertical butt weld.
live and learn.
www.vwloosenuts.com
Old 04-17-2018, 01:58 PM
  Pelican Parts Technical Article Directory    Reply With Quote #148 (permalink)
"farking Porsche hero"
Rich Lambert's Avatar
I have a feeling this one's going to turn out to be pretty interesting...nice work!
Rich
'66 911 #303872
'07 Cayman
'58 Land Rover S2 88"
Old Yesterday, 06:58 AM
  Pelican Parts Technical Article Directory    Reply With Quote #149 (permalink)
Following
Old Yesterday, 08:03 AM
  Pelican Parts Technical Article Directory    Reply With Quote #150 (permalink)
It's seems to be a bit different then what most people are doing these days. but I've never been one to "follow the crowd". I build for me and me only.
Originally Posted by Litle brother View Post
Following
www.vwloosenuts.com
Old Yesterday, 11:55 AM
  Pelican Parts Technical Article Directory    Reply With Quote #151 (permalink)
My 912E build.
It's great that there are still folks out there that goes against "the tide" and does their own thing
Keep up the top job, looking forward to see the end result
Old Today, 01:53 AM
  Pelican Parts Technical Article Directory    Reply With Quote #152 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
