help ID 2.0L aluminum pressure plate
once upon a time one could pick up the phone, call Sachs tech. support, ask them to run the old part number & get application specs.
no more.
I sent an email off about a week ago & they are either still laughing or don't have a clue.
so...
the piece is identical to a stock 2.0L pressure plate in every respect except the foot is ALU vs. cast iron.
any help appreciated.
TIA
Unclear on the concept ? Let's see if I can help.
1) You are NOT in the "fast lane" and...
2) You are NOT going "fast enough".
**News Flash**
You're in the Passing Lane. Any questions ?
Old 10-26-2017, 09:58 AM
It's a 914 ...
stownsen914's Avatar
By foot you mean the contact surface, correct? At least the older aluminum ones like for 911S had a copper facing fused onto the aluminum.
And the cover is not aluminum?
Old 10-26-2017, 11:10 AM
ASE Master Tech - 35 yrs
larrym's Avatar
ask your friend google
https://www.google.com/search?q=3082+010+031&ie=utf-8&oe=utf-8
http://www.early911sregistry.org/forums/archive/index.php/t-73346.html
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 10-27-2017, 06:41 PM
I thought I did try a Google search & didn't come up w/ much... at least not the first time around.
there seems to be some speculation that '67 & '68 S models got the copper plated type & '69 S models got this one.
time to resurrect that thread on EarlyS.
...and yes, the rest of the unit is steel.
**News Flash**
Old 10-27-2017, 08:48 PM
It's a 914 ...
Interesting. The Early S registry thread suggests that you have a 69S clutch (superseded part number), which has an aluminum foot with sprayed on iron face. And uses a different thickness disk than the earlier clutch.
Old 10-28-2017, 04:43 AM
larrym's Avatar
Arrow early S pressure plates
interesting - i still have one of these on the shelf - not copper faced - slightly used in my 914-6 behind a 2.8 for a few races with a KEP "hockey-puck" style carbon-kevlar disc
( i found that the "stock" 911S "performance" discs & PPs were not up to track abuse)
the paper tag is long gone but my notes show it to be 901.116.009.00; it is stamped Fichtel & Sachs AG Schweinfurt; - it weighs about 6.4 lbs
- inside on 5 of the fingers it is stamped 102 - 103 - F&S - 8 - 79 which may be a manufacture date?
my car in Germany in 1974 was fitted with a 2.4S & copper-faced PP "foot", but it appeared to be naught more than thin plating - and subject to wearing off - so i replaced it with the one noted above, from a source i no longer recall when i built the 2.8 in 1977
i'd guess the market for these "S" alloy PPs is quite small except for 914 guys who want to race (not likely many early S cars are so abused now)
i've since i upgraded to a 3.2
Old 10-31-2017, 11:16 AM
