Rear Seat Removal - Need Advice
I am pulling the rear seats on my 82 SC and the screw on the outer side of each seat is stuck. Any advise from wise veterans is appreciated. I did WD40 but can't seem to break it free. I'm guessing I'm not the first to have this problem, and yes I did a search.
Thanks in advance DG
________ 1982 911 SC 2013 Carrera Cab |
I heated mine with a soldering iron and then used impact driver, still a bear to get them out though
what condition my condition is in |
A ratchet with a screwdriver socket works great.
Or if you have a screwdriver, that has a spot just below the handle, that you can use a wrench on.
Tony 1968 912 Softwindow Targa 1974 911 Lime Green Targa 2013 Cayenne GTS Meteor Grey |
Thanks, I did try the wrench/screwdriver but no joy. I will try heating it or I was going to go pick up a small needle nose vice grip and give that a try too. I will let you know how I make out.
Formerly known as Syzygy
Impact driver. Just preload it to take any slack out of the space on the screw with the bit and whack it with a hammer. If you don't have a set, they're inexpensive at your FLAPS or Harbor Freight or wherever, and worthwhile picking up.
And heating it should help, too. Just don't burn your carpet. Good luck! ![]()
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
cycling has-been
This has always worked for me:
lay a 17 inch Craftsman flat blade screwdriver across the seat into the pivot screw. Get out your 3/8 inch open wrench, fit it over the shank of the screwdriver and turn - a couple of whacks with a hammer on the open-end wrench should loosen the screw. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 11-06-2017 at 07:50 AM.. |
everyone should have an impact driver, it will save you everytime
I used a 1/2" drive 3/4" wide Drag Link. I had to grind it down a bit to fit in the slot but it worked great. Cost is about $10
Lou |
use this (see below) and tap it hard to loosen it sitting prior turning it.
it doesn't need that much leverage.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Parts: https://www.instagram.com/spadescustomz_/ EGO: https://www.instagram.com/911garage_germany/ |
Yes, that did it flojo and lsf911. I picked some up at harbor freight. And as long as I was at it ordered an impact driver too.
Thanks guys |
Thread Tools | |
Rate This Thread | |
Tags |
911 sc , rear seats |
