-   -   Dash knobs (http://forums.pelicanparts.com/porsche-911-technical-forum/976747-dash-knobs.html)
Reuben911 11-06-2017 08:02 AM
Dash knobs
I installed a somewhat period correct radio to my 1984 Porsche 3.2 Carrera.
The original knobs are almost touching radio. I noticed that the 964 knobs are slightly smaller.
Anybody knows if these would work on mine ? Shaft length and threads are the same ?
Thank youhttp://forums.pelicanparts.com/uploa...1509983670.jpg
http://forums.pelicanparts.com/uploa...1509984127.jpg
Canada Kev 11-06-2017 08:25 AM
EDIT: I just checked and it looks like you've got those large knobs. You might just have to get one and see if it'll work. Sorry to not be of more assistance.
Is this a picture of your radio and knobs? If so, I don't think you're going to get any more clearance than that. At least with that radio you won't need the space to insert CDs or anything. If they were the same as those in SC... They were really quite large.
Another thing to consider is that your fog lamp knob is illuminated and I don't know if just changing the knob is even possible.
This picture shows my 1987 radio and knobs. I don't believe they are different size than your picture. However, my cigarette lighter is from a 964 to replace mine that was lost. If you look closely you might notice that it is actually slightly larger than the fog light knobs. This suggests that the 964 knobs will be the same size as your picture.
http://forums.pelicanparts.com/uploa...1509985840.jpg
Reuben911 11-06-2017 09:20 AM
Dash knobs
Hi Kev,
Thank you for the quick response.
This first pic on my post is the knobs I have, the second pic with the radio is the ones I am looking for.
Wondering if I could just change the knob without replacing the entire shaft or
if I remove the rubber around the knob and replaced them with these rings
http://forums.pelicanparts.com/uploa...1509988773.jpg
Reuben911 11-06-2017 09:23 AM
http://forums.pelicanparts.com/uploa...1509989007.jpg
Koizumi 11-07-2017 08:39 AM
Where are those rings from?
sp_cs 11-07-2017 08:47 AM
Rennline do some billet ones that may be smaller ? 25usd each iirc
Billet Dash Knobs-Rennline, Inc.
