Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 911 Technical Forum
ducktail and hp increase
Hi gus
I read on several mags the ducktail was build to increase airflow to the engine as well and it gives a slight increase in HP
did someone do a test before (no ducktail) after (ducktail) on a dyne and notice a real improvement, so more than 1 or 2 hp
thanks
Old 11-07-2017, 12:34 PM
douglas bray's Avatar
You would need a wind tunnel to test this theory. A dyno is a stationary testing tool. 8/
Old 11-07-2017, 12:47 PM
'76 911S 3.0's Avatar
I don't know about horsepower increase, but when my thermostat was unknowingly stuck closed I saw lower oil temps with the duck as opposed to without (no front cooler, just engine mounted).
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, ARP Rod Bolts, Big Port SC Heads, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 11-07-2017, 12:54 PM
Speed Metal Army General
The cool factor alone raised my HP instantly!
Old 11-07-2017, 01:10 PM
You could not be more correct
Old 11-07-2017, 01:56 PM
Reiver
Reiver's Avatar
Mine is even faster in reverse with the duck!
De Oppresso Liber
Old 11-07-2017, 03:43 PM
Bill Verburg's Avatar
Originally Posted by florent78 View Post
Hi gus
thanks
Most spoilers increase air pressure and laminar flow across the top of the spoiler where the cooling and consumed air is ingested, since engine air intake is through the area it will make for a slight increase is charge density which means a slight increase in hp.
Whales are more efficient in this regard too.
Bill Verburg
Old 11-07-2017, 04:01 PM
Under the radar
Trackrash's Avatar
Location: Sebastopol, The Republic of California. Land of wine and redwoods.
I thought spoilers spoiled the laminar flow.....
Gordon
_____________________________________
'71 911 Coupe 3,0L outlawed
<< See my Garage
Old 11-07-2017, 04:51 PM
My ducktail raised my 86 Targas RWHP to 211! I'm sure it has nothing to do with my Steve Wong chip and M&K muffler!
Old 11-07-2017, 06:06 PM
So i will do the test in a few weeks
Old 11-08-2017, 07:07 AM
Location: behind the redwood curtain, (humboldt county) california
The Porsche Story
Hi gus
thanks
IIRC, In this iconic book, Paul stated that the factory was making a real effort to reduce high speed rear lift (390 down to approx. 180 pounds).
The duck also moved the aerodynamic center of pressure rearward,, thus reducing side wind induced instability.
He also mentioned that the duck also slightly, (1-2%), reduced the aerodynamic drag.
I have seen a couple of threads mention a noticeable reduction in oil temps going back and forth between stock engine lids and ducks, although, I am at a bit of a loss to explain why, given that the oil flow to the coolers is controlled by 1 or 2 thermostats. We are left with the assumption that the duck increases the flow of air into the engine compartment to benefit both cooling and Hp.
My 74 is down for a front end refresh and a duck instalation, but, I am thinking about doing a before and after engine compartment air pressure test, at roughly 100mph, just a quick test, si I don't get busted.
Chris
Old 11-08-2017, 07:35 AM
You would not see the difference on a dyno since there is no car velocity and therefore no increase in pressure in the engine bay due to the ducktail.
When the car is moving the ducktail creates a high pressure zone just in front of it which leads to an increased pressure in the engine compartment since the grille is located right in front of the spoiler.
That will be an interesting test!
Old 11-08-2017, 08:47 AM
ducktail
It increases the HP thru the corners with downforce
Mike
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 11-08-2017, 08:54 AM
in the ducktail case, yes. i believe it would break up the laminar flow on the decklid to reduce lift and create high pressure on the face of the spoiler
Old 11-08-2017, 09:43 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
The ducktail does not add much downforce. It reduces the amount of lift or negative air pressure in the rear of the car. While driving without a ducktail, air is drawn out of the engine compartment by the lift thats created (like the wing of an aircraft). The engine fan and intake are fighting with the negative air pressure. With the Duck, there is neutral or just a bit of positive air pressure. This will definitely give a bit of extra cooling CFM's and intake CFM's to the engine. Plus it just looks real cool.
Chris
Old 11-08-2017, 11:52 AM
The tuner i m doing the dyno have a huge fan to simulate high speed
So for sure it s different from real world
But it will give a good indication
Old 11-08-2017, 12:19 PM
GOM (Grumpy Old Man)
Busta Rib's Avatar
duck tail = 1-2 hp
Pegasus decals = 5 hp
Luckily I have both!
1977 911S widebody...work in progress
My Build Thread: http://forums.pelicanparts.com/porsche-911-technical-forum/871450-busta-ribs-tale-1977-911s-widebody.html
Instagram: /bustarib and /3pedalposse
Old 11-08-2017, 01:44 PM
Flojo's Avatar
it rather helps the rear to downforce for more traction an high-speed-stability.
only in combination with front lip!
1970 911 RS clone Aerodynamics question
honestly, it DOES help! without lip 'n tale running upt to 220 on the straight was sweatty. now I run full limot with my SC 240 and feel way safer.
Regards, Flo
79 SC - Frankfurt, Germany
visit me on www.facebook.com/911garage
Old 11-09-2017, 06:01 AM
