Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
I hope last heat exchangers question
As I am reading, checking and waiting for the penetrating oil to work I found that the angle to attack the nuts is awkward not allowing socket to go straight up.
Has anyone cut the heat exchangers marked in yellow before (assume there is enough space to do this) this way one gets straight access to the nuts.
I thought I ask.
Old 11-08-2017, 01:35 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
A 13mm 6 point wobbly socket works fine. Don't expect the WD to do anything, you need heat.
jwworkshop@aol.com 206 789 6800
7613 greenwood ave n seattle wa 98103
Old 11-08-2017, 01:52 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Vintage Owner
Jack Stands's Avatar
Iíve had the best luck by heating and bending a closed end wrench to fit over the nuts (if they werenít the barrel nuts accessed through the heat exchanger). SSI used to enclose a special wrench to allow access to some of the nuts as well, so you might see if you could borrow one locally.
Otherwise, I donít see where cutting the tubes as indicated would be an issue if youíre throwing the old heat exchangers away.
84 Targa
70 914-6
73 914-6 2.7 conversion
75 GMC Motorhome
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Dentist in Westborough
faverymi's Avatar
Snap on or brand name swivel socket. Other will strip.
We are here for you mate.
Felipe Avery-Miranda
www.wda-ma.com
Old 11-08-2017, 02:07 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
faverymi's Avatar
www.wda-ma.com
Old 11-08-2017, 02:15 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
2jmotorsports's Avatar
X2 on the heat.
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
Old 11-08-2017, 02:54 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
A distributor wrench (we call it an ssi wrench) makes it easy. heat the bolts to red hot first.
A part isn't purchased until paid
Old 11-08-2017, 02:58 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
And someone will probably give you $$$ for those exchangers....
Old 11-08-2017, 02:59 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Wow
Since I don't have acetalyn torch what are my other options?
Old 11-08-2017, 03:09 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Wow
Old 11-08-2017, 03:10 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
The Mighty Pieholio
Bob Kontak's Avatar
Originally Posted by kavadarci View Post
Wow
Propane with time
Mapp gas with time.
Oxy Mapp gas with a $50-70 Bernzomatic dual feed unit from Lowes or Home Depot.
Bummer is the OXY tanks don't last for long. Maybe enough to get your nuts off the studs then the $10 tank is spent.
1981 911SC Targa
Old 11-08-2017, 03:24 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
I used a hand held Home Depot propane one successfully. Took a while to heat each fastener but all came off with a single tank.
Old 11-08-2017, 03:40 PM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Rent a small oxy/acet.
Old 11-08-2017, 04:02 PM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
Mark Salvetti's Avatar
I took the cut-them-off approach. In my case the old heater boxes where rotted away. By cutting them off you can at least get at the nuts with a Dremel.
Just make sure you cut with the heat exchangers facing down so no metal bits fall into the exhaust ports.
Mark
1979 911SC Targa
Old 11-08-2017, 04:07 PM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
Slippery Slope Expert
Steam Driver's Avatar
Broil (darn auto-correct; substitue a "K" for the "B" in that first word) works better than WD. Let it sit over night. I know heat is a good answer also or in addition to. But frankly, I've never had any issues removing them without either, even on my project car which I know hadn't been touched for at least 15 year before I got it. I can't explain that; just lucky I guess (in that respect anyway).
Use an anti-seize when you put it back together. When I had the 914-6, where the HE's had to come off for every valve adjustment, it never let me down.
Formula E - "Safe Space" racin' for the Snowflake Generation
Old 11-08-2017, 04:20 PM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
Thank you everyone for your suggestions, I'm ready.
I've taken an engine out from 71 Mercedes 250c , rebuilt and put it back in and was not nervous as with these .
Will keep you posted.
Old 11-08-2017, 04:32 PM
  Pelican Parts Technical Article Directory    Reply With Quote #16 (permalink)
We use map gas at the shop but at home, I have a propane torch that was $15 at Home Depot and I've used it a ton for loosening up rusted fasteners. While it's still hot, touch an old candle to the threads. The joint will wick in the wax instead of evaporating the penetrating oil. Then tighten the nut a 1/16 turn to break it free and then loosen it.
Old 11-08-2017, 06:24 PM
  Pelican Parts Technical Article Directory    Reply With Quote #17 (permalink)
Kano-Kroil is simply the best. it will free up anything. Here in Paducah KY we had a facility which enriched uranium for nearly 50 years. There was some serious caustic corrosion which attacked the machinery used in the production. Kroil was the go to for freeing up frozen hardware. If you have a few days just hit the nuts with it and let it sit. its amazing stuff.
Old 11-08-2017, 06:44 PM
  Pelican Parts Technical Article Directory    Reply With Quote #18 (permalink)
tops911's Avatar
PB Blaster with the engine on a stand and upside down (soak for several days) and MAPP gas, several heat cycles of heating the nut cherry red, I've done 2 engines successfully this way
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, MSD 6, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel
Old 11-08-2017, 06:51 PM
  Pelican Parts Technical Article Directory    Reply With Quote #19 (permalink)
Ok here is an update, it is bitter sweet.
Good news:
Heat exchangers are out, heat flapper boxes are out.
There was barely anything left of the flapper boxes and you can see that the heat exchangers are gone too.
One nut came out, two came out with the studs.
Bad news:
9 broke but not in, all have around 1cm left visible.
I followed all the instructions , soaked for few days, heated and all I can say, especially after seeing where these studs broke is that they are half corroded , the center portion was thinned out and the power that took to break was minimal.
I have seen videos where people use tons of power and the nuts make horrible noise on the way out, metal on metal, I had none of that light turn and it breaks.
In any case ,
I need help on what is best way to attack these studs?
I sprayed them with libricant and left them for the night.
Few pics.
Old 11-08-2017, 07:25 PM
  Pelican Parts Technical Article Directory    Reply With Quote #20 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
