tight as a bull's ass's Avatar
Originally posted by Jim Sims
There are two screws attaching the AAR; the other one's on the backside (towards front of engine). Jim
Thanks....I kinda figured that out after pulling on the thing for a while and it wouldn't come out.....
the screw in the back is really tough to get to though....damn,who designed this thing? Everything is so tight in there!!!
www.swirlednews.com/article.asp?artID=501
The data in the CD-type disc decodes easily into ASCII computer text as follows, using 8 bit binary:
"Beware the bearers of FALSE gifts & their BROKEN PROMISES. Much PAIN but still time. (Damaged Word). There is GOOD out there. We OPpose DECEPTION. Conduit CLOSING (BELL SOUND)”
The damaged word would appear to be intended as “BELIEVE”.
Old 02-14-2003, 08:53 PM
Jamie79SC's Avatar
Off the wall
TABA,
I have an off the wall thing for you to to look into. Last week, I blew and replaced the fuse for my fuel pump. (Thanks for pointing me to the correct answer Jim Sims!)
For about two weeks prior to blowing the fuse, I had the same symptom of starting and dying once or twice. Subsequent to replacing the fuse, the problem has vanished...
With a marginal fuse, could it have taken an attempt or two to get the pump motor turning? I don't know, but with a new fuse, the car starts and runs every time.
I said it was off the wall, but what could it hurt?
Jamie79SC
Old 02-14-2003, 09:37 PM
Re: Off the wall
Originally posted by Jamie79SC
TABA,
Jamie79SC,
Thanks for the tip, I'll install a new fuel pump fuse and try to start her this morning with the AAR still attached. However, when the problem happens, i do hear the fuel pump operating in the front, and it sounds normal... as it always has. I'm kinda used to the sound now.
EDIT:
UPDATE: Installed new fuse for fuel pump, car started immediately, idled at 1500 for a few minutes, then settled down to 950! wow
But it was in the garage overnight....problem was occuring only outside in the frigid cold overnight. Hmmmm....I guess the bottom line is:
- Garage your Porsche
- Porsches dont like starting in sub-zero temps.
is there a fuel additive to add so the gasoline doesn't "freeze"?
Thanks.
Old 02-15-2003, 09:08 AM
Senior Member
Superman's Avatar
FWIW, you can usually test an AAR without removing it, by using a flashlight and a mirror. Or even a piece of paper.
Mocha 1978 911SC. "Coco"
Old 02-15-2003, 10:01 AM
Procedure for testing?
Well, now i have experience removing it, can't hurt....(except the back from bending over)
Old 02-15-2003, 10:03 AM
Senior Member
Superman's Avatar
When this device is cold, there should be an opening in it. Two air hoses connect to opposite sides, and the function of the unit is to allow air to pass through. If it's out, just look through it. If not, shine a light through it and, with the mirror, see if you can see the light through the hole. Then plug it in to a 12v source and see if this causes the opening to close. No more than a few minutes.
Old 02-15-2003, 10:24 AM
