Even a Bad day is good
47silver's Avatar
mfi pump question
been cleaning the mfi in wd40 as Warren explained but have a question on how to remove the part #14. It is called "pressure valve complete", I would loke to remove this and put it in an ultrasonic cleaner to get it thoroughly clean but they appear to be stuck and i do not want to mar the threads or aperture.
Does anyone have a method of removing these?
1975 911S Targa
Silver Anniversary Edition
Old 11-09-2017, 12:42 PM
47silver's Avatar
figured it out
there are a very tight friction fit. I used a very powerful magnet to pull them out. machined to very tight tolerances.
1975 911S Targa
Old 11-09-2017, 06:45 PM
After removing the piston, 13+14 may be tapped out from below. Very carefully, using a plastic rod or similar.
Btw, this manual is highly recommended http://http://911mfi.com
Hans / 1972T MFI coupe
Old 11-10-2017, 06:23 AM
356RS's Avatar
The correct tool is a internal threaded rod that screws into the top threaded section of the pressure valve. Once the rod is screwed into the pressure valve, you pull the valve out.
Mark Jung
Bend, OR
MFI Werks.com
Old 11-10-2017, 06:52 AM
47silver's Avatar
thanks all, i see the threads on the outside of the valve, the magnet worked for me but it is a powerful rare earth magnet that you find in hard drives,, may be good to get that tool or make one though..
1975 911S Targa
Old 11-10-2017, 08:11 PM
